How to Swap Display Identity (Identities)
2009-12-03T02:46:30+00:00
Windows 7 - Display 'A' Philips primary display - Display 'B' IBM secondary display.  A shows as Identity 2 and B shows as Identity 1.  I want to reverse these.  Reason is that the cursor currently travels from display B to A and I need it to go the other way - due to physical location of displays
2009-12-03T03:38:29+00:00
In the Screen Resolution window, under Change the appearance of your displays , click and drag one of the monitors to its correct location vs. the other one.   The Identity numbers don't matter.
129 additional answers
    2018-01-27T07:45:42+00:00
    Click on the display you want as primary.  Then scroll down to "Multiple Displays".  check the check box "Make this my main display".
