In the Screen Resolution window, under Change the appearance of your displays , click and drag one of the monitors to its correct location vs. the other one. The Identity numbers don't matter.
How to Swap Display Identity (Identities)
Windows 7 - Display 'A' Philips primary display - Display 'B' IBM secondary display. A shows as Identity 2 and B shows as Identity 1. I want to reverse these. Reason is that the cursor currently travels from display B to A and I need it to go the other way - due to physical location of displays
129 additional answers
2016-12-15T00:35:52+00:00 To be clear, there is a difference between the "main display" designation, and the numbered display identities each device has.
While it is certainly possible to make displays numbered 2, 3, 4, et. al. the main display device, this does not itself address the identity issue. It causes a number of problems for many people's configurations, and in all these years Microsoft have not seen fit to address this issue in any Windows version. I had this problem on Windows 7, and I still have it in Windows 10. Any official response has alternately been (to paraphrase) "there is no problem", or when it is painstaking pointed out that this does cause problems that it is simply "too hard" or even "impossible" to fix at the OS-level.
2017-01-04T17:55:34+00:00 Is it possible to be a port thing. From what i've read and my personal exp. DVI appears to be second to the HDMI.
May be something like COM 1,2 etc.
2017-01-04T22:25:51+00:00 It certainly is related to ports, but that alone does not answer why it has to be this way at the end user level. At the very lowest level Windows perhaps has no control over how it addresses each monitor, but the whole point of an OS is to abstract low level function to behave in ways the user requires them to. I accepted these limitations with IRQs and such in the DOS days, but I find it hard to accept that there's no way around this using a modern OS.
2017-01-09T13:44:01+00:00 Hey,
I was facing the same issue. At home, and for me, the main drawback of these wrong monitor identifiers was when I pressed "Win+P" to quickly switch from my PC monitor to my TV : "Computer only" displayed image on TV and vice-versa.
I managed to switch these identifiers, regardless the "main display" used to show icons and taskbar. I think I used the same trick as the registry hack under XP, but through the device manager. Here is my exact procedure :
- Both displays plugged, switch to extend mode.
- In device manager, delete all items (2 expected) under Monitors
- Physically unplug the monitor you want to see numbered 2, or the "projector".
- In device manager, a Monitor may have been added, delete it.
- Reboot
- Check your PC monitor is numbered 1
- Plug again the second monitor (TV in my case)
- First monitor should keep its number 1
This worked for me on Win7. Hope it'll help !
Stephane
