How to Swap Display Identity (Identities)
2009-12-03T02:46:30+00:00
Windows 7 - Display 'A' Philips primary display - Display 'B' IBM secondary display.  A shows as Identity 2 and B shows as Identity 1.  I want to reverse these.  Reason is that the cursor currently travels from display B to A and I need it to go the other way - due to physical location of displays
2009-12-03T03:38:29+00:00
In the Screen Resolution window, under Change the appearance of your displays , click and drag one of the monitors to its correct location vs. the other one.   The Identity numbers don't matter.
129 additional answers
    2010-01-19T02:29:29+00:00
    THE number of each display really MATTER for some apps. Its quite confusing to try to change this setup if its correctly set in drivers (ATI for me), even in color management. . . Only place, where you are (most possibly) NOT allowed to change this setting is in "Change the appearance of your displays"
    Anybody know where is hidden "oldschool-display-dialog" ? ?
    2010-01-19T06:04:49+00:00
    Yes the number does not matter as said in this post already.
    You get a virtual Desktop in which there are two Monitors
    Just move the Monitor in the Virtual Desktop and Mouse cursor would move as you would like it to be
    2011-02-05T13:17:14+00:00
    The identity number MATTERS a whole lot.
    I am not talking about small annoyance of right click Move to Monitor 1/2/3
    Some games which support dual monitor will INSIST on using dsplay number 2 as auxillary.
    2011-06-16T07:06:01+00:00
    Agreed - the monitor identity (number) DOES matter.
    Case in point - I use three displays connected via DVI(2) and DP(1).
    I can set up the monitors in DVI easily BUT as soon as I connect the DP monitor, the DP monitor ALWAYS takes the identify of #1.
    The problem then is that when I deselect 'Extend' and go to 'computer only' via Win+P, the DP is the active monitor because it is #1 monitor (but the DP needs to be of the extended displays) - I can't force the DP to take the identity of monitor #2 or #3; it takes on #1 always.
    Some say - well then just set the #2 display as primary, which it does become the primary display BUT it is still is #2 and is extended; turning off the extended displays turns off #2 and all reverts to #1.
    So you can see that switching from running only one monitor to running multiple monitors, the numbering identity is very significant. I have no idea why the DP demands to be #1.
    Another suggestion would be to make the DP monitor the main monitor - NOT AN OPTION.
    There was a registry hack available for XP and Vista to change identities, but this no longer works with Windows 7.
    There are programs like Ultramon and Catalyst Control Center that can renumber monitors but they only renumber internally and have no effect upon the monitor identity at the OS level.
    With more and more users running multiple monitors, Microsoft needs to address this problem.
