Turn NUM LOCK on at start-up
2009-12-27T01:45:17+00:00
How do you edit InitialKeyboardIndicators in the registry editor so num lock is on at start-up? One instruction I read said to change the value to 2.  The number that is already present is 2147483648 which I have no idea what it stands for!  Can anyone help me out here? Thanks
2009-12-27T08:21:38+00:00
By default the numlock status is the same as it was in when you properly shut down the computer. If it was on when you shut it down it will be on when you again turn the computer on.
Richard Urban
Microsoft MVP
Windows Desktop Experience/Security
"BJ55" wrote in message news:b6f5c70d-a053-431 1-946d-ba9e8879f644...
2010-06-04T13:27:04+00:00
I haven't read through every reply, but just in case there has not been an answer for this, here is what you do.
By default, NumLock, CapsLock, and ScrollLock are set to off on power up in WindowsXP.  If you want to modify this to allow one or all of them to be on by default at power up, follow the below instructions.
  1. Click Start
  2. Click Run
  3. Type RegEdit
  4. Expand to HKEY_Users
  5. Expand .Default
  6. Expand Control Panel
  7. Expand Keyboard
  8. Find sting value InitialKeyboadIndicators. (By default this will be set to '0' which means Num Lock, Scroll Lock, and Caps Lock are all turned off.)
  9. Double click the "InitialKeyboardIndicators" string value and make the following changes.
  • 0 - Turns off Num Lock, Caps Lock, and Scroll Lock
  • 1 - Turns on Caps Lock
  • 2 - Turns on Num Lock
  • 3 - Turns on Caps Lock and Num Lock
  • 4 - Turns on Scroll Lock
  • 5 - Turns on Caps Lock and Scroll Lock
  • 6 - Turns on Num Lock and Scroll Lock
  • 7 - Turns on Caps Lock, Num Lock, and Scroll Lock
Exit the Registry. When you restart, the new setting will take effect
137 additional answers
    2017-07-14T21:54:10+00:00
    This is a great resource. I will keep the Registry Editor for future reference.
    But, I got to where you mention 0,1,2, to change operation and when I opened it it had a highlighted number 2147483748.  I did not want to touch or change that. So I was unable to follow the rest of your advice.  Let me know what else I should do.
    2017-07-14T22:12:25+00:00
    WHOA!  It worked!  I scrolled further down and found and opened where the long list of numbers you mentioned were. The numbers were not exactly the same as mine but I took a chance, clicked, saw where to enter 2.  I restarted my computer and 'HANDS IN THE AIR WOW FACE'.  Thanks
    2017-08-30T20:14:32+00:00
    Richard Urban
    Microsoft MVP
    ‭binary value : 10000000000000000000000000000000‬ can be converted to
    2147483648 unsigned int
    or -1 signed int
    -1 means : not configured ==> default system value
