Turn NUM LOCK on at start-up
2009-12-27T01:45:17+00:00
How do you edit InitialKeyboardIndicators in the registry editor so num lock is on at start-up? One instruction I read said to change the value to 2.  The number that is already present is 2147483648 which I have no idea what it stands for!  Can anyone help me out here? Thanks
2009-12-27T08:21:38+00:00
By default the numlock status is the same as it was in when you properly shut down the computer. If it was on when you shut it down it will be on when you again turn the computer on.
Richard Urban
Microsoft MVP
Windows Desktop Experience/Security
"BJ55" wrote in message news:b6f5c70d-a053-431 1-946d-ba9e8879f644...
2010-06-04T13:27:04+00:00
I haven't read through every reply, but just in case there has not been an answer for this, here is what you do.
By default, NumLock, CapsLock, and ScrollLock are set to off on power up in WindowsXP.  If you want to modify this to allow one or all of them to be on by default at power up, follow the below instructions.
  1. Click Start
  2. Click Run
  3. Type RegEdit
  4. Expand to HKEY_Users
  5. Expand .Default
  6. Expand Control Panel
  7. Expand Keyboard
  8. Find sting value InitialKeyboadIndicators. (By default this will be set to '0' which means Num Lock, Scroll Lock, and Caps Lock are all turned off.)
  9. Double click the "InitialKeyboardIndicators" string value and make the following changes.
  • 0 - Turns off Num Lock, Caps Lock, and Scroll Lock
  • 1 - Turns on Caps Lock
  • 2 - Turns on Num Lock
  • 3 - Turns on Caps Lock and Num Lock
  • 4 - Turns on Scroll Lock
  • 5 - Turns on Caps Lock and Scroll Lock
  • 6 - Turns on Num Lock and Scroll Lock
  • 7 - Turns on Caps Lock, Num Lock, and Scroll Lock
Exit the Registry. When you restart, the new setting will take effect
137 additional answers
    2016-05-11T20:22:21+00:00
    Actually, I later found that my "solution" worked only that one time and returned to numlock "off" on subsequent shutdowns and startup.
    2016-05-11T20:28:09+00:00
    Apparently, Microsoft doesn't care about this.
    I have been a user since the days of Windows 3.1 - well before Win 95 and Win 98  or XP and my desktop computer always powered up with the Numlock "ON"
    Only after installing Widows 10 did the problem appear.
    2016-05-26T08:35:59+00:00
    I only shutdown a couple of times a month. I hibernate the machine at the end of the day. I NEVER have the numlock on , since I work on a smaller keyboard without the number's pad. EVERY single time I turn on the machine, the numlock is automatically ON and my password fails.
