Turn NUM LOCK on at start-up
2009-12-27T01:45:17+00:00
How do you edit InitialKeyboardIndicators in the registry editor so num lock is on at start-up? One instruction I read said to change the value to 2.  The number that is already present is 2147483648 which I have no idea what it stands for!  Can anyone help me out here? Thanks
2009-12-27T08:21:38+00:00
By default the numlock status is the same as it was in when you properly shut down the computer. If it was on when you shut it down it will be on when you again turn the computer on.
Richard Urban
Microsoft MVP
Windows Desktop Experience/Security
"BJ55" wrote in message news:b6f5c70d-a053-431 1-946d-ba9e8879f644...
2010-06-04T13:27:04+00:00
I haven't read through every reply, but just in case there has not been an answer for this, here is what you do.
By default, NumLock, CapsLock, and ScrollLock are set to off on power up in WindowsXP.  If you want to modify this to allow one or all of them to be on by default at power up, follow the below instructions.
  1. Click Start
  2. Click Run
  3. Type RegEdit
  4. Expand to HKEY_Users
  5. Expand .Default
  6. Expand Control Panel
  7. Expand Keyboard
  8. Find sting value InitialKeyboadIndicators. (By default this will be set to '0' which means Num Lock, Scroll Lock, and Caps Lock are all turned off.)
  9. Double click the "InitialKeyboardIndicators" string value and make the following changes.
  • 0 - Turns off Num Lock, Caps Lock, and Scroll Lock
  • 1 - Turns on Caps Lock
  • 2 - Turns on Num Lock
  • 3 - Turns on Caps Lock and Num Lock
  • 4 - Turns on Scroll Lock
  • 5 - Turns on Caps Lock and Scroll Lock
  • 6 - Turns on Num Lock and Scroll Lock
  • 7 - Turns on Caps Lock, Num Lock, and Scroll Lock
Exit the Registry. When you restart, the new setting will take effect
137 additional answers
    2014-01-01T20:39:01+00:00
    U are wrong, read the whole thread, and if u cant figure it out, posting ur negative response is NOT the way to go
    Haha and how is you telling him HE is wrong, any different from him telling the other person they were wrong?? And he IS right, and you ARE wrong, it does not reboot to on unless you edit the reg
    2014-02-28T18:22:28+00:00
    It's not on when I restart or when I shut down fully and turn the computer back on. Regardless of whether it was on or off when I shut down, it always reverts to OFF when reboots.
    I have tried disable fast boot in power settings, no change. I tried changing the registry value to 2 or to 2147483650, no change. I tried those values with and without parentheses, no change. Tried also 2147483648 and then 0 in these registry keys, still no change. Num lock refuses to stay on after POST. (It IS set to ON in BIOS)
    UPDATE: Changing the value to 80000002 worked for me. (http://frankapi.wordpress.com/2012/10/15/windows-8-and-numlock-on/)
    2014-03-16T11:17:38+00:00
    Thanks beegiel.  Worked great.  I'll thank you every time I boot up!
