When are you going to fix the overheating Microsoft Wireless Mouse Nano receiver?
2010-03-06T08:15:47+00:00
I bought a Microsoft wireless mouse 4000 a month ago. Yesterday it's receiver died on me. I suspect short circuit. After some research, I've realized that I was not alone with this problem, it could be a serial fault.
Once the question appeared on the forum before (http://social.answers.microsoft.com/Forums/en-US/w7hardware/thread/727a8f10-4aaf-4f1e-bea1-3a73f7e62cf9) but the issue was quickly dismissed.
I bought the thing whole on a trip in Europe and can't have it replaced. Thus the question is, whether to trust Microsoft for the second time and buy the same mouse again, or opt for something else? I need a mouse that works on rough surfaces. But as of now, I may need to overcome my liking for the device and opt for Logitech's Anywhere, unless you reassure me that you will have the transceiver replaced soon.
2010-04-04T01:38:24+00:00
Microsoft Wireless Mobile Mouse 4000
Microsoft Replacement phone#: 800-933-4750.  Product ID = D5D-00001.  Have your 4000 mouse handy when you call them.  They will need the Product ID (PID) from the bottom.
They will replace yours for free .  Replacements carry a 3 yr warranty.  You must keep the PID of the original mouse for the replacement warranty.
53 additional answers
    2010-03-06T20:57:19+00:00
    I'm not sure why you can't replace it where you are now, but I can confirm that the notebook bluetrack mouse (http://www.microsoft.com/hardware/mouseandkeyboard/ProductDetails.aspx?pid=002) transeiver does not overheat.  I have two of them, as well as the desktop version.
    2010-03-24T11:24:31+00:00
    My mouse worked about one month. Now transceiver is very hot and partially melted.
    I am dissapointed with a terrible quality of the product. This mouse is dangerous!!!
    2010-03-24T14:36:44+00:00
    It should be noted that most USB device connection to USB port will get hot.  USB specs indicate that USB is provide power over the port.  There seems to be only one method of limiting the receiver of over heating:  Use a USB "extension" cable.  The USB extension cable USB A plug should be the plug that will head up, thus "saving" your receiver.
    2010-03-24T15:32:22+00:00
    Some external USB hubs have been known to run USB devices to the point where they can melt. I run an MS keyboard dongle on the back panel of my desktop PC and it has NEVER run hot..
    Mike Hall MVP - Windows Desktop Experience http://msmvps.com/blogs/mikehall/
