Method 8, resetting IE 8 under tools>internet options>advanced>reset worked for me
Connection Problem Troubleshooting - 'The remote device or resource won't accept the connection Detected'
My desktop computer is a Windows Vista Home Premium 32 Bit. The problem occurred about 2 months ago, while it was still Vista, but please note that I upgraded to Windows 7 last night and the problem is still the same.
My Internet Explorer, computer updates, iTunes, and everything else, EXCEPT my AOL, won't work. My connection says 'excellent'. (Everything on my laptops hooking up to my wireless are working just fine, only my desktop is having this problem)
When I click on Internet Explorer, it says 'Internet Explorer cannot display the webpage', and when I click 'diagnose connection problem' it says 'Problems found- The remote device or resource won't accept the connection Detected'
I spoke to my Comcast internet provider all morning about this problem: She stated that on her side the internet connections were working properly. She ran me through steps including replugging the router cords, checking how the internet connection is set up, and some other things, but everything was how it was supposed to be. She suggested that maybe AOL could be the issue and to delete it since I was no longer using it, so I did, but nothing has changed. So, then she told me to contact Windows..(not sure how to call Windows technical support without paying $59?, but found this forum)
Is anyone familiar with this problem and could please help, or to at least point me in the right direction?
Also, please let me know if you need any other information about the problem.
Lily
141 additional answers
2014-08-06T05:29:48+00:00 Hello Rufus,
Thank you for the reply.
Did you try using suggestions in my response on July 3, 2014?
Please use those suggestions and reply with results. We will be glad to assist you further.
Thank you
2014-08-14T19:20:31+00:00 Tried Option 8, no joy. Tried the regedit fix, same thing. The 'proxy server' check box keeps coming back, and the browser keeps saying the 'proxy server isn't responding'. My kids, who like Google Chrome, are also having proxy server problems. Physical connections all look good and it says it's got an internet connection - it's just not reaching it.
I'm about ready to delete the whole damned thing and go with Linux and Firefox or whatever. Been dealing with this off and on for far too long with far too many generic answers that are worse than useless. Levels of frustration are reaching epic proportions. Maybe use it as a boat anchor instead...naaah, it still works as a stand-alone machine...hmmm...
2014-08-17T05:21:49+00:00 Hello David,
Thank you for the update.
I appreciate your patience.
I would suggest you to refer this article and check if it helps.
[Fiddler] Fix "The proxy server isn't responding" Problem Caused by Fiddler
Please keep us informed about the status of the issue.
Thank you
