Locally connected Printer shows as offline on Windows 7 network after initially working
2010-02-06T13:46:55+00:00
Ok, have checked similar threads wihich got no successful answers.
I have a PC with Epson printer connect directly via USB. Print driver installed correctly.  Works fine.
Windows 7 Ultimate (32 bit) no security other than windows firewall and microsoft security essentials.
Laptop connected wirelessly to PC.  On same network and homegroup, file and media sharing all working fine.
Laptop running Windows 7 Ultimate (32 bit) same security as PC.
When I add a network printer it finds printer on PC and correctly installs driver etc.  Printer appears in devices and will print the first couple of times.
However, by the next day the network printer shows up as "offline" in the print spooler on the laptop.  Documents simply stack up.
The PC does not go to sleep and is left on all of the time except for the monitor which is switched off.  Printer works fine on PC, indeed with docs stuck on the laptop I can still print directly from the PC - even this does not show the printer as online on the laptop.
Have checked that the printer spooler on laptop is running and set to automatic.
Epson unable/unwilling to help - have found a similar thread with no answer - anybody any guesses as to what to try?
Many thanks
2010-05-03T09:50:43+00:00
I had a similar problem and for me  the Problem is with the EPSON driver.
My printer was connected wirelessly to my network, I had IP address and could ping it but WIN 7 showed it as OFFLINE.
I then went and had a look at the printer driver, (start, Devices and printer, selected the epson printer then under printer management, customise printer, ports then configure port)
And noticed that for Standard TCP/IP Port it was pointing to a different IP than that what my printer currently had. I edited it to match what the printer was and it came ONLINE.
When you turn your printer off, its IP address goes back in your routers pool to be reassigned.
The Epson windows driver still has the old IP. You turn your printer on and your router happens to give it a different IP from last time. It now doesn't match with what the Epson driver stored before and tells you it is OFFLINE.
For me,  rather than changing the IP in the driver each time this happend I assigned a static IP (fixed host ) address in my router to match my printers MAC address. This way it always gives my printer the same address everytime and no more fake OFFLINE messages appear in Windows.
This is an Epson driver problem, not a windows problem.
2010-05-28T07:49:43+00:00
Set the IP address of the printer to a static address as stated earlier in this thread.  If you add the printer again by browsing the network, the Standard TCP/IP port will only work as long ast the printer retains the same IP.  If the print device support DNS or WNS name registration you can add a Standard TCP/IP Port using the hostname rather than a transient IP address for DHCP enabled print devices.
Alan Morris Windows Printing Team; Search the Microsoft Knowledge Base here: http://support.microsoft.com/search/Default.aspx?adv=1
88 additional answers
    2011-01-07T15:20:19+00:00
    HERE IS THE ANSWER: you don't have to use a static IP address if you use the printer HOST NAME rather than the IP Address. 1) Open the Printer Properties and go to the Ports tab. 2) Highlight the port your printer is using and click Configure Port. 3) In the Printer Name or IP Address field, replace the IP address with the Host Name of the printer. You can usually find the printer host name by printing the network summary report (network configuration report) from your printer's panel. 4) Click OK, then Close the Properties screen. Give it a minute or 2, and your PC should resolve the Host Name and go back on line.
    2011-01-14T18:14:57+00:00
    boatguypat's advice seems clear, but it hasn't worked for me.
    I did (as suggested) replace the printer's IP address by the name "Brother" (which is the name shown on a test page, and the name in the router's IP table). Nevertheless, any time I turn off the printer, when I subsequently turn it on again, Windows 7 stubbornly reports Brother as "Offline" and offers no way to make it return to "Online" status.
    The printer has IP address 10.0.0.107. Looking at the Ports, I find I now have TWO ports listed, one with id 10.0.0.107 and no associated name, and another with id 10.0.0.107_1 and the name "Brother".
    If I try to delete either of them, the request is rejected with the message "the requested resource in in use" -- even though neither shows any job in its queue.
    Thats the bad news. The good news is that I can still go back to the list of devices, delete the printer, then add it back again. It seems silly to have to do it that way, but it works.
    2011-01-18T16:00:01+00:00
    Wow that is strange. This has been working fine for me. The only other suggestion i might make is to completely remove the printer, then re-install it using the hostname. If that doesn't work i guess it's a fixed IP address for you. Sorry.
