Locally connected Printer shows as offline on Windows 7 network after initially working
2010-02-06T13:46:55+00:00
Ok, have checked similar threads wihich got no successful answers.
I have a PC with Epson printer connect directly via USB. Print driver installed correctly.  Works fine.
Windows 7 Ultimate (32 bit) no security other than windows firewall and microsoft security essentials.
Laptop connected wirelessly to PC.  On same network and homegroup, file and media sharing all working fine.
Laptop running Windows 7 Ultimate (32 bit) same security as PC.
When I add a network printer it finds printer on PC and correctly installs driver etc.  Printer appears in devices and will print the first couple of times.
However, by the next day the network printer shows up as "offline" in the print spooler on the laptop.  Documents simply stack up.
The PC does not go to sleep and is left on all of the time except for the monitor which is switched off.  Printer works fine on PC, indeed with docs stuck on the laptop I can still print directly from the PC - even this does not show the printer as online on the laptop.
Have checked that the printer spooler on laptop is running and set to automatic.
Epson unable/unwilling to help - have found a similar thread with no answer - anybody any guesses as to what to try?
Many thanks
2010-05-03T09:50:43+00:00
I had a similar problem and for me  the Problem is with the EPSON driver.
My printer was connected wirelessly to my network, I had IP address and could ping it but WIN 7 showed it as OFFLINE.
I then went and had a look at the printer driver, (start, Devices and printer, selected the epson printer then under printer management, customise printer, ports then configure port)
And noticed that for Standard TCP/IP Port it was pointing to a different IP than that what my printer currently had. I edited it to match what the printer was and it came ONLINE.
When you turn your printer off, its IP address goes back in your routers pool to be reassigned.
The Epson windows driver still has the old IP. You turn your printer on and your router happens to give it a different IP from last time. It now doesn't match with what the Epson driver stored before and tells you it is OFFLINE.
For me,  rather than changing the IP in the driver each time this happend I assigned a static IP (fixed host ) address in my router to match my printers MAC address. This way it always gives my printer the same address everytime and no more fake OFFLINE messages appear in Windows.
This is an Epson driver problem, not a windows problem.
2010-05-28T07:49:43+00:00
Set the IP address of the printer to a static address as stated earlier in this thread.  If you add the printer again by browsing the network, the Standard TCP/IP port will only work as long ast the printer retains the same IP.  If the print device support DNS or WNS name registration you can add a Standard TCP/IP Port using the hostname rather than a transient IP address for DHCP enabled print devices.
Alan Morris Windows Printing Team; Search the Microsoft Knowledge Base here: http://support.microsoft.com/search/Default.aspx?adv=1
88 additional answers
    2010-11-05T10:03:20+00:00
    Hi Carvl,
    The fact is that the printers are not shown in the devices and printers screen????? You can print to the within Office say for instance Word but you can not print a test page because of the fact that the printer is not shown. Within IE it is not possible to adress the printer becaus it is not shown ther in the list of devices. When I install the same printer with USB it is working pefectly but when I install it based on Parallel it does strange things....
    Kind regards, AJ.
    2010-11-07T17:40:19+00:00
    I fixed my same problem by going to "add a printer" option. When all of the names of the printers and the location of each was found, I used the IP address for the printer that was there. Then I went into the properties for the printer I was trying to get to work and updated the Port Address to the matching address.  i.e.- The "Port name" for the printer is 192.168.1.105 and the address WAS the same. But after I did the add a printer method I found the printer to be at 192.168.1.106. Just one digit higher, I assume dynamically created. All I did was change the IP address to this new setting and it worked right away. Hope this confusing description helps.
    2011-01-02T03:31:03+00:00
    I tried everything I could understand (some of the suggestions were Greek to me) and then I restored the system to a date before Windows did an automatic update and voila -- the printer is now online.  I think that's what started the problem.  If not, the printer is still working now, so I'm relieved.
