Battery "plugged in, charging", but NOT charging.
2010-01-20T18:11:35+00:00
I recently upgraded from Windows Vista Home Premium to Windows 7 Home Premium.  With Vista, my battery performed very admirably and I never had any issues.  As soon as I upgraded to Windows 7, I now encounter the following problem:
When I mouse over the battery icon in the system tray, it says "19% available (plugged in, charging)".  However, the battery isnot charging at all.  The little battery level animation stops, and, even though the system seems tothink it is charging my battery, it is not.  When I first installed the new OS, the battery would charge to 69% with the same problem, then it went up to 75% for about 1 week before plummeting so that, now, my battery charge ceiling is 19%, which, as you can imagine, lasts about 15 minutes on battery power.
After several redundant and unhelpful communications with Microsoft, I thought perhaps someone on this board might have experience with this issue or suggestions on what I might try.
Please note this is NOT the seemingly frequent problem that some people have with the battery saying "plugged in, not charging", as my system specifically says the battery IS charging when it is not.
It took me some time to even get Microsoft to agree to troubleshoot the problem as they insisted it was because my battery is a bit old.  However, this happens with both batteries I own, using either charger that I have, and, as I said before, it ONLY started right when I clean installed Windows 7.
Thanks in advance for any help!
Ryan
2010-01-21T17:41:39+00:00
Hello Ryanr1083,
We have come across with this issue. I would suggest you to get in touch with the system manufacturer and you may have to replace the bettery.
 You can refer to the links mentioned below, which has similar issues.
http://social.answers.microsoft.com/Forums/en-US/vistahardware/thread/f06a5bae-0caf-4eae-ae56-1aec1e1291e6
http://social.answers.microsoft.com/Forums/en-US/w7performance/thread/8f41bb6e-3702-4dd3-8d34-d5a4d1cff915
http://social.answers.microsoft.com/Forums/en-US/vistahardware/thread/765fc712-678d-4c8e-aa00-6abb00e3eb62
http://social.answers.microsoft.com/Forums/en-US/vistaperformance/thread/8a5f9b80-800a-46ce-bdeb-435f411fb7dc
I hope this information helps. Please get back to us if you have any more questions about this issue.
Mir - Microsoft Support ****Visit our http://social.answers.microsoft.com/Forums/en-US/answersfeedback/threads
49 additional answers
    2012-05-15T18:36:56+00:00
    yes did as you said and it worked ,charged battery back up to 100%.ran on battery to 50% swiched off and refit charger back ,plugged in not charging on again owell worked once
    2012-08-08T05:41:17+00:00
    Really? I upgraded from Windows 7 Home premium to Windows 7 Ultimate, and I had no problems. Did you upgrade to the correct bit?
    2012-08-08T09:49:30+00:00
    I think  upgrading  to windows 7 ultimate should fix the problem, like EdgarTecum said
    2012-08-08T16:22:53+00:00
    also, when my pc was running good with windows 7 home premium. it had no problems with the battery or anything. did you upgrade using a legit upgrade?
