Want to set 'num lock' to be on and active at Windows 7 Log-in screen on new HP G60-530US laptop.
2009-11-18T21:19:38+00:00
Have tried a number of methods to have num-lock activated at Windows log-on that were suggested for XP and Vista, but with no success. These include making registry changes to set
InitialKeyboardIndicators to a value of 2 at
HKEY_USERS.DEFAULT\Control Panel\Keyboard and
HKEY_CURRENT_USER\Control Panel\Keyboard
and also running a numlock.vbs script in
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup
as per Microsoft support site http://support.microsoft.com/default.aspx/kb/314879
Regardless of what I have tried, including shutting down with num lock activated, num lock will be 'off' when the computer is rebooted. There is no setting in the BIOS to control num lock. Does anyone have another suggestion?
2010-07-01T17:15:38+00:00
I experienced the same problem myself; fortunately, the solution is simple.  For some reason, the default value of some of the registry keys (not all) were changed in windows 7, which causes the system to apparently ignore the InitialKeyboardIndicators settings in the other locations.  All that is requireded is the performance of a search of the registry using regedit for that key.  It is important to use the find function to locate ALL keyboard keys forInitialKeyboardIndicators and set them to the same value setting.  The value options are as follows:
0 - Turn all indicators Off (NumLock, CapsLock, ScrollLock)
1 - Turn CapsLock On
2 - Turn NumLock On
3 - Turn CapsLock and NumLock On
4 - Turn ScrollLock On
5 - Turn CapsLock and ScrollLock On
6 - Turn NumLock and ScrollLock On
7 - Turn all indicators On (NumLock, CapsLock, ScrollLock)
In my case, the string value was some 7 or 8 digit number such as 21765430.  These entries are the cause of the reboot change in the num lock status.  If you want it on when you boot, set the string value to 2 in all the keys with numeric values.  Problem solved!
43 additional answers
    2010-07-24T19:44:13+00:00
    How sdo you nget into BIOS in Windows 7?
    2010-07-24T20:08:52+00:00
    You don't get in the BIOS in Windows 7, nor in any other operating
    system.
    How to get into your BIOS depends, not on Windows, but on what
    motherboard/BIOS you have. As a matter of fact, you have to access the
    BIOS before Windows even starts to boot. One common way is to press
    the Del key when you first power on, but that's not necessarily right
    for your computer. Watch the screen carefully when you first boot;
    there's often a message there telling you what to do. If not, check
    your system documentation or check with your vendor.
    Also look here: http://michaelstevenstech.com/bios_manufacturer.htm
    Or just try the Del key. There's a good chance that's correct for you.
    Ken Blake
    2010-07-30T17:49:08+00:00
    Tahnks a lot CEPtor.
    For me this configuration is fine. In orher hand my NumLock ligth is on after reboot.
    2010-09-10T20:01:44+00:00
    2 - Turn NumLock On
    I am scared to mess with the registry on my brand new laptop, but this is annoying enough for me to try.
    Just to be clear, you say that on your computer, "the string value was some 7 or 8 digit number such as 21765430."  Am I correct that you replaced this 7 or 8 digit number with just one digit, namely "2"?
    So in your list above, all 7 components would be set to just 2.
    Right?
