Operation could not be completed (error 0x00000015). The device is not ready.
2010-02-18T22:11:11+00:00
After many problems, I managed to get my Epson RX600 printer/scanner working under Windows 7 Professional.
Now the error in the title line keeps appearing when I try to scan.  Epson support won't help as they say its a Microsoft problem.  Any suggestions appreciated.
2011-01-26T20:35:43+00:00
Well i have found out a perfect way to solve this problem. It worked for me so I'll be hoping it works for you too
This is how you have to do it. You need to enable WIA - Windows Image Acquisition. now to do that follow these steps.
  1. Click on start or the Window thingy.
  2. Type Services or Services.msc in the search part.
  3. Now scroll to the following services in the window that got opened.
Remote Procedure Call (RPC)
DCOM Server Process Launcher
RPC Endpoint Mapper
Shell Hardware Detection
Enable those services. To do so right click on them, click properties and make it automatic. Once you enable all of them start them. After all the services are started scroll for "Windows Image Acquisition" make this automatic too and start it. Just reboot your PC and you should be good to roll :D.
Scan all you want :) Problem solved.
2010-02-24T19:24:53+00:00
What happens if you just click OK and continue the scanning operation?
As according to the below provided article this error message can be safely ignored in case of a picture scanning operation -
http://support.microsoft.com/kb/2018464
Also the link for the driver I provided works for both Vista 32-bit and 64-bit operating system as stated by the Epson website. The link directs to TWAIN Driver v3.04A for Windows Vista 32-bit and 64-bit Editions.
****Hope this helps. Let us know the results.
Meghmala – Microsoft Support
69 additional answers
    2011-11-16T19:29:06+00:00
    Enabling Shell Hardware Detection service aas "automatic" alone corrected the problem.  I be lieve the latest version of PC Tools Registery Mechasing Windows Performance Optimization changed the service to manual.
    2011-11-18T04:33:49+00:00
    once you restart your printer. it worked in my case.
    2011-11-20T18:00:15+00:00
    I had the very same error message, but in my case it was a CanoScan scanner (LIDE 200). I was able to successfully install the scanner on both my laptop and my wife's PC, but only on my PC were there problems.
    My son-in-law was eventually able to find the cause of the problem. By typing in 'services' into the 'search programs and file' box near to the windows start button, he then selected 'Services (Local)' and then scrolled down to the 'Shell Hardware Detection' entry. For some unknown reason this had been disabled, but by re-enabling it to 'Automatic' the scanner miraculously started again.
    It worked for me - so it's maybe worth a look. My OS is Windows 7 (32bit)
