Operation could not be completed (error 0x00000015). The device is not ready.
2010-02-18T22:11:11+00:00
After many problems, I managed to get my Epson RX600 printer/scanner working under Windows 7 Professional.
Now the error in the title line keeps appearing when I try to scan.  Epson support won't help as they say its a Microsoft problem.  Any suggestions appreciated.
2011-01-26T20:35:43+00:00
Well i have found out a perfect way to solve this problem. It worked for me so I'll be hoping it works for you too
This is how you have to do it. You need to enable WIA - Windows Image Acquisition. now to do that follow these steps.
  1. Click on start or the Window thingy.
  2. Type Services or Services.msc in the search part.
  3. Now scroll to the following services in the window that got opened.
Remote Procedure Call (RPC)
DCOM Server Process Launcher
RPC Endpoint Mapper
Shell Hardware Detection
Enable those services. To do so right click on them, click properties and make it automatic. Once you enable all of them start them. After all the services are started scroll for "Windows Image Acquisition" make this automatic too and start it. Just reboot your PC and you should be good to roll :D.
Scan all you want :) Problem solved.
2010-02-24T19:24:53+00:00
What happens if you just click OK and continue the scanning operation?
As according to the below provided article this error message can be safely ignored in case of a picture scanning operation -
http://support.microsoft.com/kb/2018464
Also the link for the driver I provided works for both Vista 32-bit and 64-bit operating system as stated by the Epson website. The link directs to TWAIN Driver v3.04A for Windows Vista 32-bit and 64-bit Editions.
****Hope this helps. Let us know the results.
Meghmala – Microsoft Support
69 additional answers
    2010-02-24T14:36:49+00:00
    I tried your suggestion and when the program ran it errored stating the version of Windows was not supported.  I assume this is because the installation is for 64 bit and using compatibility mode takes it backwards. I did try running it as normal but the original error message [as in header] still appears. If I go into the printer options to set a scanning profile, I'm told it isn't ready/initialized.
    S
    2010-02-24T21:31:36+00:00
    If I OK the error message the scanner isn't useable.
    2010-02-25T14:26:08+00:00
    Don't ask me how I did it but it now works!!  I cleared the printer from devices, uninstalled all Epson software and cleaned the Registry.  Then I downloaded all the drivers etc from the Epson site as per item 4 in your original reply and installed them.
    Thanks, Meghmala, for your help in resolving this.
    Snowytop
