Blue Double Arrows
2010-03-10T14:16:08+00:00
What are the blue double arrows that sometimes appear on my desktop icons and pictures and how can I get rid of them?
2010-03-10T15:05:51+00:00
Do you have Norton 360 or some other Norton security suite?   If so, that's why.  The double blue icons means there are files that haven't been backed up. It can be turned off.  Go to Norton 360 http://www.symantec.com/norton/support/dtree.jsp?pvid= and learn how to turn it off, reboot and they will be gone.  For anyone that does have Norton 360, if you kept it turned on, when you backed up the files, the icon would turn a solid green arrow instead of the 2 blue arrows.
I hope this helps.
Good luck!
Lorien - MCSE/MCSA/Network+/A+ --- If this post helps to resolve your issue, please click the "Mark as Answer" or "Helpful" button at the top of this message. By marking a post as Answered, or Helpful you help others find the answer faster.
47 additional answers
    2016-05-25T12:35:52+00:00
    http://answers.microsoft.com/en-us/windows/forum/windows_10-start/mysterious-blue-double-arrows-added-to-windows/fad079c4-6498-4543-b4ec-b547a2bd00eb?page=3
    check my post
    I appreciate the post and I do know you can tweak the registry.  I'd honestly prefer not to do that...I'd like the actual problem to be resolved..hopefully it will be in a new patch or something.
    2016-05-25T12:42:40+00:00
    So to stop this from happening you need to disable OneDrive, its a backup feature. Green indicates the file has been backed up to One Drive, blue has not yet been backed up.
    This was my conclusion after i first posted about it. Maybe not the same for others. You can also select which folders to be backed up when you initially set up One Drive.
    This is not one drive...I do not have it signed in or in use in any way...So I think your icons may be different than what you're referring to.
    2016-05-25T12:52:29+00:00
    check my post
    double blue arrows mean my folders and files are compressed, that's what they are on my windows 10 pc.  I removed them by unchecking the compress option under properties.  Warning, it took hours for a couple of folders that contained at least a GB of data and I have an intel i5 processor with an 8gb ram.
    2016-05-25T12:57:16+00:00
    check my post
    THat sounds right.  What's odd though is the icons that have the blue double arrows for me...aren't compressed..I don't have anything selected for compression..
