Blue Double Arrows
2010-03-10T14:16:08+00:00
What are the blue double arrows that sometimes appear on my desktop icons and pictures and how can I get rid of them?
2010-03-10T15:05:51+00:00
Do you have Norton 360 or some other Norton security suite?   If so, that's why.  The double blue icons means there are files that haven't been backed up. It can be turned off.  Go to Norton 360 http://www.symantec.com/norton/support/dtree.jsp?pvid= and learn how to turn it off, reboot and they will be gone.  For anyone that does have Norton 360, if you kept it turned on, when you backed up the files, the icon would turn a solid green arrow instead of the 2 blue arrows.
I hope this helps.
Good luck!
Lorien - MCSE/MCSA/Network+/A+ --- If this post helps to resolve your issue, please click the "Mark as Answer" or "Helpful" button at the top of this message. By marking a post as Answered, or Helpful you help others find the answer faster.
47 additional answers
    2017-06-22T15:26:59+00:00
    Thank you so much.  This issue has bugged me for several years now as the blue box blocks half of the photo preview icon in Microsoft Explorer.  I never would have guessed that it was Norton 360 doing this automatically.  If you have Norton 360...try this solution first.  The MOST HELPFUL REPLY adjusting Microsoft Explorer picture folder properties does not fix this problem.
    2017-08-18T16:53:46+00:00
    2017 update -- I think now those two blue arrows pointing at each other can mean that the files inside that folder have been compressed, as in, that you chose to compress files on your computer in order to make more room on your hard drive.
    2017-08-18T20:35:20+00:00
    Did not have Norton.  Have never used Norton.
    2017-12-13T23:30:26+00:00
    do not have Norton
