Blue Double Arrows
2010-03-10T14:16:08+00:00
What are the blue double arrows that sometimes appear on my desktop icons and pictures and how can I get rid of them?
2010-03-10T15:05:51+00:00
Do you have Norton 360 or some other Norton security suite?   If so, that's why.  The double blue icons means there are files that haven't been backed up. It can be turned off.  Go to Norton 360 http://www.symantec.com/norton/support/dtree.jsp?pvid= and learn how to turn it off, reboot and they will be gone.  For anyone that does have Norton 360, if you kept it turned on, when you backed up the files, the icon would turn a solid green arrow instead of the 2 blue arrows.
I hope this helps.
Good luck!
Lorien - MCSE/MCSA/Network+/A+ --- If this post helps to resolve your issue, please click the "Mark as Answer" or "Helpful" button at the top of this message. By marking a post as Answered, or Helpful you help others find the answer faster.
47 additional answers
    2012-05-16T14:07:59+00:00
    The arrows are generated by Norton Securiy Suite on my computer. To get rid of them, open Norton, go to SETTINGS and on the right side of the screen de-select "Backup Status Overlays"
    2013-12-06T19:43:47+00:00
    Thank you, so much!
    2013-12-07T07:33:29+00:00
    Thanks, I was wondering if something was wrong with my computer and then I realised it was that! :)
    2015-10-16T07:23:47+00:00
    I know this is an old topic, but i am suddenly seeing these blue arrows on my icons in windows 10 and i do not nor have i ever had any Norton products on this PC, so what do i do to rid myself of them?
