How many passes before defrag finishes?
2010-06-28T19:50:57+00:00
Original Title: "Defragmenting hard drive"
I am try to defrag my hard drive. It's on its 4th pass in 24 hours. How many passes does it make before it's done?
2010-06-28T22:55:23+00:00
have seen as high as 7.
they seem to get faster the further along it goes.
look into using AUSLOGICS degragger instead.
faster and also has an option to move system files to the front.
<MARQUEE bgColor=#ffff00 height=22 behavior=alternate width="35%" scrollAmount=2 scrollDelay=9>mikeyshd</MARQUEE>
"hijiisan" wrote in message news:*** Email address is removed for privacy *** .com...
*I am try to defrag my hard drive. It's on its *
*4th pass in 24 hours. How many passes does it make before it's done?*
* Programs you are having problems with
* Error messages
* Recent changes you made to your computer
* What you have already tried to fix the problem
185 additional answers
    2012-10-17T12:49:33+00:00
    I'm going through the defrag process for the first time on my laptop.
    I purchased it new on 23rd August 2012
    installed the must have programmes for me was going to defrag next time I powered up,
    little did I know that I would be taken ill and would not be able to use the laptop till 15 October 2012 at 2pm
    The first thig I did was to start the defrag programme it's still running some 48 hours later and Defrag is now on pass 7:32% consolidated I have a 300GB drive that has 238.9 GB free
    can anyone suggest how much longer the defrag will take?
    2012-10-29T18:19:48+00:00
    If you click the tell me more at the top it says it may take "Several minutes to a few hours".
    Mine is at pass 9 after 4 days.
    Must be another example of the Microsoft clock.
    2012-10-29T18:37:08+00:00
    What happens if we stop the operation? Does it help at all or not?
    2012-11-02T07:08:04+00:00
    Doing my defrag right now and it's on its 12th defrag. Wanted to see how bad it could go!
