How many passes before defrag finishes?
2010-06-28T19:50:57+00:00
Original Title: "Defragmenting hard drive"
I am try to defrag my hard drive. It's on its 4th pass in 24 hours. How many passes does it make before it's done?
2010-06-28T22:55:23+00:00
have seen as high as 7.
they seem to get faster the further along it goes.
look into using AUSLOGICS degragger instead.
faster and also has an option to move system files to the front.
<MARQUEE bgColor=#ffff00 height=22 behavior=alternate width="35%" scrollAmount=2 scrollDelay=9>mikeyshd</MARQUEE>
"hijiisan" wrote in message news:*** Email address is removed for privacy *** .com...
*I am try to defrag my hard drive. It's on its *
*4th pass in 24 hours. How many passes does it make before it's done?*
* Programs you are having problems with
* Error messages
* Recent changes you made to your computer
* What you have already tried to fix the problem
185 additional answers
    2017-05-07T18:20:12+00:00
    Mine is on its 30th pass X_x
    2017-05-26T17:47:31+00:00
    My machine is now at pass 8 after 21 hours.  Pass 7 took at minimum 5 hours.  I fail to see how it is getting faster as it goes along.  I would like to know at what point can it be stopped manually without disrupting the drive?
    2017-06-09T10:56:52+00:00
    I seen 12 pass around 5 hours and still going on.
    2017-06-11T20:45:00+00:00
    I have a 60GB partition that I am defragging.  I am on pass 30 - it was only 11% fragmented when I started.  What happens if I click Stop Operation.  How many passes can I expect on such a small hard drive?
