How many passes before defrag finishes?
2010-06-28T19:50:57+00:00
Original Title: "Defragmenting hard drive"
I am try to defrag my hard drive. It's on its 4th pass in 24 hours. How many passes does it make before it's done?
2010-06-28T22:55:23+00:00
have seen as high as 7.
they seem to get faster the further along it goes.
look into using AUSLOGICS degragger instead.
faster and also has an option to move system files to the front.
<MARQUEE bgColor=#ffff00 height=22 behavior=alternate width="35%" scrollAmount=2 scrollDelay=9>mikeyshd</MARQUEE>
"hijiisan" wrote in message news:*** Email address is removed for privacy *** .com...
*I am try to defrag my hard drive. It's on its *
*4th pass in 24 hours. How many passes does it make before it's done?*
* Programs you are having problems with
* Error messages
* Recent changes you made to your computer
* What you have already tried to fix the problem
185 additional answers
    2016-03-20T10:33:51+00:00
    How do you know what the pass is?  I have seen the blue wheel going around for over 12 hours but there is no indication of the pass.
    2016-04-14T05:21:42+00:00
    11 passes and counting. It's been about 3 hours
    2016-04-14T11:27:29+00:00
    Thank you to everybody who has responded.  I think if I had been informed as to what to expect, I would not have been concerned.  In the past I was able to view a graph and increasing percentage numbers.  Now I just saw the blue wheel going indefinitely around.
    2016-05-20T19:20:30+00:00
    I am currently on Pass 8 but it only took like 10 minutes, is that normal?
