How many passes before defrag finishes?
2010-06-28T19:50:57+00:00
Original Title: "Defragmenting hard drive"
I am try to defrag my hard drive. It's on its 4th pass in 24 hours. How many passes does it make before it's done?
2010-06-28T22:55:23+00:00
have seen as high as 7.
they seem to get faster the further along it goes.
look into using AUSLOGICS degragger instead.
faster and also has an option to move system files to the front.
<MARQUEE bgColor=#ffff00 height=22 behavior=alternate width="35%" scrollAmount=2 scrollDelay=9>mikeyshd</MARQUEE>
"hijiisan" wrote in message news:*** Email address is removed for privacy *** .com...
*I am try to defrag my hard drive. It's on its *
*4th pass in 24 hours. How many passes does it make before it's done?*
* Programs you are having problems with
* Error messages
* Recent changes you made to your computer
* What you have already tried to fix the problem
185 additional answers
    2014-01-31T18:46:00+00:00
    I have two 2tb hard drives 60% full I defrag weekly it takes about 5-10 min each. Remember the longer you wait the longer it it will take. Keeping 0% fragmented all the time will keep it running smooth
    2014-02-02T20:05:35+00:00
    Mine is at thousands and still continuing. Is there a problem?
    2014-02-13T05:53:34+00:00
    I made a mistake and before I wanted to launch a new site thought I should defrag my drive since I've written and deleted so many times/files.  Oh boy.. what a mistake.. it took 6 days to just go through pass 1.. can't risk touching it and loosing data.. if anybody else ever thinks of doing such a thing.. DON'T DO IT!!! You'll be sorry..   it's a powerful quad core machine with 16 gigs of ram.. can't stop it.. can't reboot it.. STUCK till it finishes.. what a dumb mistake .. if anybody has any suggestions (besides stop it and re-image.. etc) can't be done.. it's a live web server with sites on it
    2014-02-20T12:38:55+00:00
    I am on pass 23 after leaving it running all night it has a 500Gb drive which had only 6Gb left on the partition so i will be resizing when it has finished
