How many passes before defrag finishes?
2010-06-28T19:50:57+00:00
Original Title: "Defragmenting hard drive"
I am try to defrag my hard drive. It's on its 4th pass in 24 hours. How many passes does it make before it's done?
2010-06-28T22:55:23+00:00
have seen as high as 7.
they seem to get faster the further along it goes.
look into using AUSLOGICS degragger instead.
faster and also has an option to move system files to the front.
<MARQUEE bgColor=#ffff00 height=22 behavior=alternate width="35%" scrollAmount=2 scrollDelay=9>mikeyshd</MARQUEE>
"hijiisan" wrote in message news:*** Email address is removed for privacy *** .com...
*I am try to defrag my hard drive. It's on its *
*4th pass in 24 hours. How many passes does it make before it's done?*
* Programs you are having problems with
* Error messages
* Recent changes you made to your computer
* What you have already tried to fix the problem
185 additional answers
    2013-02-17T16:30:51+00:00
    Mines on pass 8 on a 250GB Sata Drive, 64% as we speak, and it seems to have gotten slower lol! It must vary depending on the Type of drive, it's data transfer speed etc...
    2013-02-19T09:07:30+00:00
    I've had 37 passes in about half an hour, it seems like it could go up to anything.
    And Gerry, yes good point. I wasn't multi-tasking and unfortunately don't understand "windows managed pagefile or a fixed size pagefile".
    2013-02-19T09:22:46+00:00
    http://www.winhelp.us/index.php/windows/enhancing-windows-performance.html/set-paging-file-to-a-fixed-size-in-windows.html
    Setting a  fixed pagefile and and having it contiguous ( in one Block ) can be difficult where the free disk space is less than 50%. Achieving may also be more difficult if you rely on the Windows provided defragmenter to defragment.
    2013-03-18T01:00:56+00:00
    I use Windows 8, and my defrag went up to 10 passes. It was the first time I used the defrag on this computer, so I'm not sure if it goes higher or not. It didn't take that long either. It ran for, like, 45-60 minutes.
