trying to get replacement USB transceiver for my wireless keyboard
2009-12-21T19:55:17+00:00
I've lost the USB transceiver for my wireless keyboard/mouse set, trying to find out where I can get a replacement for it without having to get a whole new keyboard & mouse just for that one transceiver.
Microsoft Natural Wireless Ergonomic Keyboard 7000
Transceiver says "Microsoft 2.4GHz Transceiver v2.0"
thanks!
2014-07-11T22:36:34+00:00
I talked with Microsoft today and, yes, the person who answered stated that there are NO replacements for the receiver, and I would have to buy a new set up.  After asking to talk to someone who had some technical knowledge and getting no where, I asked for a supervisor.  I was on hold for several minutes, but I was not going to give up.  Finally a supervisor answered and after explaining that I knew something about computers, he offered to send me a whole new unit, free of charge.  And to top that off, he said he would expidite the order and it would ship to me in 1 - 3 days.
The number that I called is 800-360-7561, option 2.  Make sure that you ask to talk to a supervisor, as the people that answer haven't a clue.  They just read off of a script.  I hope that this helps someone out there.  Microsoft wants to keep their ccustomers and WILL do what it takes to keep them.
Have a great day.
169 additional answers
    2016-08-06T14:27:21+00:00
    > there is not a way to simply rewrite the code on the USB dongle so it speaks with your existing keyboard/mouse.
    Yes, that can be easily done.  The code is 'saved' probably in a flash memory and that flash memory one should be able to reprogram that code eg. some program/app on a PC that reprograms the flash to a new code matching the KB&M.  Msft should be able to make such an app/program very easily, that dongle would contain a microcontroller addressable through the usb connection.
    2016-08-07T04:22:06+00:00
    They recommended that you get a logitech unifying receiver, because it will automatically find the usb accessories plugged into the USB port. Just downloaded the software and had it search for the hardware.
    You must be kidding !
    Logitech's receiver doesn't work even with other Logitech wireless keyboards/mice, let alone those manufactured by another company like Microsoft.
    I do have a unifying receiver, I just tested it with a MS Wirelss 800 combo set and a MK220 Logitech combo set, and it's not even detecting the Microsoft mouse/keyboard (while with the Logitech MK220 which is NOT unifying-supported, it would detect them but tell you that "the mouse is not supported by this receiver , you need to use the OEM receiver that came with it".
    Your story is very hard to believe.
    2016-08-10T00:34:55+00:00
    Hi, everyone. I agree it sounds weird, but I also received the same indication once calling to microsoft: get an universal usb unifying receiver. They were not allowed to say the brand, but once I've asked if it was from Logitech, they've confirmed.
    Did anyone try it? Did it work??
    2016-08-10T14:20:48+00:00
    Do they have an email address?
    I do not live in the US.
