Network connection shows that it is connected but whatever I try to go online I have Unidentified Network and No Internet Access showing
2009-12-15T16:42:21+00:00
Windows 7 - Unidentified Network No Internet Access
I have a new Packard Bell PC with Windows 7 preinstalled.  I have had the tower replaced once, as it was suspected that the issue was caused by a fault with the wireless card.
I initially connected to the internet - albeit slowly and briefly.  It shows that it is connected with my network but whatever I try I have Unidentified Network and No Internet Access showing
I can connect through a 3mobile dongle.  Just not via the wireless card.
I have looked at so many suggested fixes, and have tried as many as I am able, but I am so lost as to what to try next.
Any suggestions?
Many thanks
2012-03-18T15:22:23+00:00
Hello again
We have some problems with this happening at work. We found out that the issue has something to do with IP version 6.
We found out that disableling the IPv6 protocol helped.
I welcome you to try it.
First off you need to start a command prompt with admin rights. This can be done by pressing the start button, choosing "All Programs" --> Accessories --> and rightclicking Commandprompt, choose "Run as administrator".
Im sitting on a Danish language box, and the translations are made from memory.
Once you got your command prompt type the following:
netsh <press enter>
interface ipv6 <enter>
isatap set state state=disabled <enter>
The prompt will respond with an "OK" if it was succesfull.
to exit type:
quit <enter>
If you need to reverse the change and return to standard settings, do the above but replace the word in the isatap command "disabled" with "enabled". Very very few networks run Ip version 6, so the change has pretty low impact, but the bug is really annoying.
Let me hear if it helps.
2010-12-08T18:57:41+00:00
Try disabling the McAfee network agent service. Run > "msconfig" > Services. I disabled the mcafee network agent and the mcafee firewall core service.
This solution fixed it for me!
3 month old Dell laptop, preinstalled with McAfee trial suddenly had this "Unidentified Network no internet access". Thanks to this forum for the solution.
2009-12-16T05:21:51+00:00
To troubleshoot your issue you may try the below methods one by one.
Method 1: Update the network driver.
Steps to update network driver:
1.    Click on start button.
2.    In the search box type devmgmt.msc and then press enter.
3.    Select the network card device and right click on it
4.    Now select properties.
5.    In the properties window, under Driver tab, click on Update Driver button.
6.    After the installing the updates restart the computer.
For more information visit: http://windows.microsoft.com/en-us/windows7/Update-a-driver-for-hardware-that-isnt-working-properly
Method 2: Try resetting the TCP/IP stack.
To reset the TCP/IP stack go to this article and either click on "Fix it for me" or follow the instructions to fix it yourself: http://support.microsoft.com/kb/299357 .
If still the same problem persists then try the next method.
Method 3: Here you need to troubleshootusing the Network troubleshooter in Windows 7 and check for the issue to do that follow the below provided link.
http://windows.microsoft.com/en-US/windows7/Using-the-Network-troubleshooter-in-Windows-7
Hope this helped
Thanks and Regards:
Suresh Kumar- Microsoft Support.
2009-12-28T03:24:10+00:00
hello,
i tried this , and it worked.
*removed*
hope that helped.
184 additional answers
    2012-04-29T11:24:00+00:00
    Hello Everyone..
    Please help me resolve this Unidentified Network issue. This has started coming after my Sony Vaio Laptop motherboard was changed, becuase of some hardware problem. I tried the following but the problem still persists
    a/. Deleting network driver and restarting the maching. Installed the driver again and updated it to
    the latest
    b/. Disabled all the services other than Microsoft services and restarted the laptop
    c/. Disable IP Helper service and DHCP client service and restarted the laptop
    d/. Network diagnostic gives Wireless Connection doesnt have a valid IP Configuration. Tried resetting the IPV4 and IPV6 setting using elevated comand prompt .
    The ipconfig settings are as follows
    Windows IP Configuration
       Host Name . . . . . . . . . . . . : DrYatha
       Primary Dns Suffix  . . . . . . . :
       Node Type . . . . . . . . . . . . : Hybrid
       IP Routing Enabled. . . . . . . . : No
       WINS Proxy Enabled. . . . . . . . : No
    Wireless LAN adapter Wireless Network Connection:
       Connection-specific DNS Suffix  . :
       Description . . . . . . . . . . . : Intel(R) Centrino(R) Advanced-N 6200 AGN
       Physical Address. . . . . . . . . : 00-23-14-06-71-38
       DHCP Enabled. . . . . . . . . . . : No
       Autoconfiguration Enabled . . . . : Yes
       Link-local IPv6 Address . . . . . : fe80::cde5:d28d:af91:857e%22(Preferred)
       Autoconfiguration IPv4 Address. . : 169.254.133.126(Preferred)
       Subnet Mask . . . . . . . . . . . : 255.255.0.0
       Default Gateway . . . . . . . . . :
       DHCPv6 IAID . . . . . . . . . . . : 369107732
       DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-13-3A-22-8C-00-24-BE-65-7A-ED
       DNS Servers . . . . . . . . . . . : fec0:0:0:ffff::1%1
                                           fec0:0:0:ffff::2%1
                                           fec0:0:0:ffff::3%1
       NetBIOS over Tcpip. . . . . . . . : Enabled
    Ethernet adapter Local Area Connection:
       Media State . . . . . . . . . . . : Media disconnected
       Description . . . . . . . . . . . : Atheros AR8131 PCI-E Gigabit Ethernet Controller (NDIS 6.20)
       Physical Address. . . . . . . . . : 00-24-BE-EC-47-1C
    Ethernet adapter Bluetooth Network Connection:
       Description . . . . . . . . . . . : Bluetooth Device (Personal Area Network)
       Physical Address. . . . . . . . . : 50-63-13-DB-A2-9E
    Tunnel adapter isatap.{CD40AA7C-180A-41BA-B841-54974EB12AC6}:
       Description . . . . . . . . . . . : Microsoft ISATAP Adapter
       Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
    Tunnel adapter Local Area Connection* 11:
       Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
    Tunnel adapter isatap.{9961FF90-B862-4E14-AC52-C22BD9476B58}:
       Description . . . . . . . . . . . : Microsoft ISATAP Adapter #2
    Tunnel adapter 6TO4 Adapter:
       Description . . . . . . . . . . . : Microsoft 6to4 Adapter
    Tunnel adapter isatap.{97A8C9D1-D405-4B4F-BB4E-01BF772BE7AE}:
       Description . . . . . . . . . . . : Microsoft ISATAP Adapter #4
    Tunnel adapter isatap.{808F88FB-B648-4C58-99E6-49C100905B12}:
       Description . . . . . . . . . . . : Microsoft ISATAP Adapter #5
    Kindly help
    Rajesh
