Network icon show red "X" even though wireless adapter is connected and working...
2010-02-01T15:49:01+00:00
Running Windows 7 Ultimate and I recently tried installing the new softwarer/driver for the Netgear WPN111 wireless adapter. Before the install everything worked normally with the older version 2.1, but after installing version 3.0 it does not.
When the network icon in systray comes up you get the disconnected icon with the circle while it searches. Once it finishes it goes back to the disconnected icon, even though it is now connected to my wireless.
Here are somethings I've tried:
  • clearing all network locations
  • clearing tray notification cache using CCleaner
  • uninstalling the adapter itself from device manager including checking delete driver
  • removing the wireless network and adding it back manually
  • hiding and unhiding the network icon in the tray
  • uninstalling version 3.0 and reinstalling version 2.1
  • uninstalling version 3.0 and reinstalling version 3.0
  • restarting the Network Location Awareness service
  • disabling and renabling the Network Location Awareness service after a reboot
Here are some things I've noticed:
  • the network icon used to change to the wireless icon during connecting and once connected, now it always shows the wired network icon
  • tried connecting to a wired connect and the same thing happens, it goes back to displaying the icon with the red "X" even though it is connected
  • booted into safe mode with networking and the icon works normally in safe mode
Any suggestions or help would be greatly appreciated. It's one of those things that doesn't really affect the functionality of Windows, but it's annoying as all.
2010-02-12T18:43:16+00:00
Hmm... a complete reinstall seems a bit premature at this point. Why not first try the following:
  1. Clear all preferred wireless networks from your network configuration. Right click to manage, click wireless on the left, delete everything.
  2. Ensure the network manager service is running.
A reboot may be required, but it was not in my case.
100 additional answers
    2010-09-01T16:58:57+00:00
    hi mine does the same i use wireless and ethernet and when using eth the wireless connection shows red and one can not see the eth net square icon , only when i painfully disable the wireless connection does square show and then when it is working fine it shows a red x- why- why have they combined the status to one icon position on the task bar - it a microsoft bug and they need to fix it
    hereme was here.
    2010-09-11T22:40:12+00:00
    sorry accidently proposed as an asnswer, however, if anyone has messed with the services, then you may find that instead of showing a number of bars on the network icon, you find the red ex with no bars, i am positive it is to do with a service being disabled, however i can not find out what service i need 2 re enable. i am scared of messing the laptop up.
    2010-09-24T17:25:20+00:00
    hi mine is doing the same,
     and guess what microsoft say   " it is by design" this is what "cody" says !!!!!!!!!!!!!!
    Hereme,
    What you're describing is by design. If you would like to see this feature change in future versions of Windows, you can leave your feedback here:
    Windows 7 Feedback
    Thanks for using Microsoft Answers!
    Cody C
    and what i say
    what a load of cobblars "it is by design to show the wrong status of a connection" what bad bad reply and i have to send feedback in to ask to get the "by design corrected-"- come on microsoft pull your finger out , you have our money but do not design stuff that works.
    hereme was here.
    2010-11-04T23:49:20+00:00
    Has anyone got a fix for this bug that actually works as there are a lot of answers out there and none of them work
