Problem Event Name: BEX, error message
2009-05-19T18:52:36+00:00
I'm working on a tool which is used mainly for replacing the data source location of Crystal XI report batch, this tool is working normally, but when trying to replace data source location of some reports and mainly when looping on report tables to replace the data source of each table, a Bex error is raised
by the way, DEP feature is disabled using command ==>  bcdedit.exe /set {current} nx AlwaysOff
so
i need to know what is BEX error ?
why this error is raised when working with some reports not all of them?
how can i disable or work around this problem?
Thanks a lot.
Windows for home | Other | Apps
2009-07-03T16:32:16+00:00
Hi m.2,
Thanks for giving that information. It was indeed helpful.
BEX refers to Buffer Overflow Exception. For more details on BEX, kindly visit http://technet.microsoft.com/en-us/library/cc738483(WS.10).aspx
Could you please provide some more information? I have included a snapshot of a BEX error for your reference. Please post the snap shot so that I can get you the resolution.
Problem signature:
Application Name:          iexplore.exe
Application Version:       7.0.6001.18000
Application Timestamp:     47918f11
Fault Module Name:         ntdll.dll
Fault Module Version:      6.0.6001.18000
Fault Module Timestamp:    4791a7a6
Exception Offset:          00087ba6
Exception Code:            c000000d
Exception Data:            00000000
  OS Version:                6.0.6001.2.1.0.768.3
Locale ID:                 1037
Additional Information 1:  fd00
Additional Information 2:  ea6f5fe8924aaa756324d57f87834160
Additional Information 3:  fd00
Additional Information 4:  ea6f5fe8924aaa756324d57f87834160
Take care.
Regards,
Avash M
81 additional answers
    2011-12-23T22:36:46+00:00
    this right here is mine when i try to go on the video section of my files then it says error and this is wat it says in the additional info plz help
    Application Name: explorer.exe
    Application Version: 6.1.7600.16768
    Application Timestamp: 4d6878c3
    Fault Module Name: QuickTime.qts_unloaded
    Fault Module Version: 0.0.0.0
    Fault Module Timestamp: 4e13ba08
    Exception Offset: 6141a9e9
    Exception Code: c0000005
    Exception Data: 00000008
    OS Version: 6.1.7600.2.0.0.256.1
    Locale ID: 1033
    Additional Information 1: 0a9e
    Additional Information 2: 0a9e372d3b4ad19135b953a78882e789
    Additional Information 3: 0a9e
    Additional Information 4: 0a9e372d3b4ad19135b953a78882e789
    2011-12-31T22:23:43+00:00
    i got the same problem too...here :
    Application Name: hl2.exe
    Application Version: 0.0.0.0
    Application Timestamp: 4ea78f27
    Fault Module Name: steamclient.dll
    Fault Module Timestamp: 4ef09506
    Exception Offset: 000111c0
    Exception Code: c0000409
    OS Version: 6.1.7601.2.1.0.256.1
    Locale ID: 1033
    Additional Information 1: bbff
    Additional Information 2: bbffde2df54039c1425e5f0b4d5d53bb
    Additional Information 3: 60ff
    Additional Information 4: 60ff63b45633a3de64204e6ebfd1a3b1
    ANYONE PLEASE HELP SOMEHOW..
    2012-03-22T11:28:56+00:00
    Hi abdul,
    We have the following error windows server 2008:
    Problem signature:
      Application Name: WINHTMLH.exe
      Application Timestamp: 4e2fbde6
      Fault Module Name: rtutils.dll
      Fault Module Version: 6.1.7601.17514
      Fault Module Timestamp: 4ce7b9ac
      Exception Offset: 00001e1a
      OS Version: 6.1.7601.2.1.0.16.7
      Locale ID: 1033
      Additional Information 1: a7aa
      Additional Information 2: a7aa91f17ea749d42a4de3b390fa5b3d
      Additional Information 3: a7aa
      Additional Information 4: a7aa91f17ea749d42a4de3b390fa5b3d
    can you help?
    thanks
    2012-07-24T01:06:35+00:00
    I have this problem also. This is information when IEExplorer stops
    Description
    Problem signature
    Files that help describe the problem
