Problem Event Name: BEX, error message
2009-05-19T18:52:36+00:00
I'm working on a tool which is used mainly for replacing the data source location of Crystal XI report batch, this tool is working normally, but when trying to replace data source location of some reports and mainly when looping on report tables to replace the data source of each table, a Bex error is raised
by the way, DEP feature is disabled using command ==>  bcdedit.exe /set {current} nx AlwaysOff
so
i need to know what is BEX error ?
why this error is raised when working with some reports not all of them?
how can i disable or work around this problem?
Thanks a lot.
Windows for home | Other | Apps
2009-07-03T16:32:16+00:00
Hi m.2,
Thanks for giving that information. It was indeed helpful.
BEX refers to Buffer Overflow Exception. For more details on BEX, kindly visit http://technet.microsoft.com/en-us/library/cc738483(WS.10).aspx
Could you please provide some more information? I have included a snapshot of a BEX error for your reference. Please post the snap shot so that I can get you the resolution.
Problem signature:
Application Name:          iexplore.exe
Application Version:       7.0.6001.18000
Application Timestamp:     47918f11
Fault Module Name:         ntdll.dll
Fault Module Version:      6.0.6001.18000
Fault Module Timestamp:    4791a7a6
Exception Offset:          00087ba6
Exception Code:            c000000d
Exception Data:            00000000
  OS Version:                6.0.6001.2.1.0.768.3
Locale ID:                 1037
Additional Information 1:  fd00
Additional Information 2:  ea6f5fe8924aaa756324d57f87834160
Additional Information 3:  fd00
Additional Information 4:  ea6f5fe8924aaa756324d57f87834160
Take care.
Regards,
Avash M
81 additional answers
    2011-07-12T06:30:40+00:00
    Thank you so much.Wonderfull share.
    Thank you.
    2011-08-10T09:10:28+00:00
    hi
    i have been having a problem with BEX too where when i try log into messenger plus it when i click sign in it always says that messenger has stopped working
    this is the problem details that appeared
    PLEASE help me try to fix this
    thank you!
    Problem signature:
    Application Name: msnmsgr.exe
    Application Version: 14.0.8117.416
    Application Timestamp: 4bc935af
    Fault Module Name: unknown
    Fault Module Version: 0.0.0.0
    Fault Module Timestamp: 00000000
    Exception Offset: 0196191c
    Exception Code: c0000005
    Exception Data: 00000008
    OS Version: 6.0.6000.2.0.0.768.2
    Locale ID: 3081
    Additional information about the problem:
    LCID: 1033
    Read our privacy statement:
    http://go.microsoft.com/fwlink/?linkid=50163&clcid=0x0409
    2011-10-06T14:39:01+00:00
    Having same problem with BEX
    Does it mean i have to reinstall my msnmsgr?
    Exception Offset: 00a31d2c
    OS Version: 6.1.7601.2.1.0.768.3
    Locale ID: 17417
    2011-11-29T06:31:42+00:00
    Hello All,
    I get the bellow  BEX error message.
    Please Assist.
    Problem signature:
    Application Name: fxssvc.exe (Fax Service)
    Application Version: 6.0.6001.18000
    Application Timestamp: 47919551
    Fault Module Name: StackHash_9930
    Exception Offset: 6937ca36
    OS Version: 6.0.6002.2.2.0.272.7
    Locale ID: 2057
    Additional Information 1: 9930
    Additional Information 2: 47cdd5e73a3af82decff8242443be38b
    Additional Information 3: 1645
    Additional Information 4: a69e611592d981126255ddab092374d8
    Regards
    Lefteris Krashias
