Problem Event Name: BEX, error message
2009-05-19T18:52:36+00:00
I'm working on a tool which is used mainly for replacing the data source location of Crystal XI report batch, this tool is working normally, but when trying to replace data source location of some reports and mainly when looping on report tables to replace the data source of each table, a Bex error is raised
by the way, DEP feature is disabled using command ==>  bcdedit.exe /set {current} nx AlwaysOff
so
i need to know what is BEX error ?
why this error is raised when working with some reports not all of them?
how can i disable or work around this problem?
Thanks a lot.
Windows for home | Other | Apps
2009-07-03T16:32:16+00:00
Hi m.2,
Thanks for giving that information. It was indeed helpful.
BEX refers to Buffer Overflow Exception. For more details on BEX, kindly visit http://technet.microsoft.com/en-us/library/cc738483(WS.10).aspx
Could you please provide some more information? I have included a snapshot of a BEX error for your reference. Please post the snap shot so that I can get you the resolution.
Problem signature:
Application Name:          iexplore.exe
Application Version:       7.0.6001.18000
Application Timestamp:     47918f11
Fault Module Name:         ntdll.dll
Fault Module Version:      6.0.6001.18000
Fault Module Timestamp:    4791a7a6
Exception Offset:          00087ba6
Exception Code:            c000000d
Exception Data:            00000000
  OS Version:                6.0.6001.2.1.0.768.3
Locale ID:                 1037
Additional Information 1:  fd00
Additional Information 2:  ea6f5fe8924aaa756324d57f87834160
Additional Information 3:  fd00
Additional Information 4:  ea6f5fe8924aaa756324d57f87834160
Take care.
Regards,
Avash M
81 additional answers
    2011-05-17T15:06:12+00:00
    i got aproblem like this,..how should i solve it..
    Problem signature:
    Application Name: Skype.exe
    Application Version: 5.3.0.111
    Application Timestamp: 4dac4a84
    Fault Module Name: StackHash_e98d
    Fault Module Version: 0.0.0.0
    Fault Module Timestamp: 00000000
    Exception Offset: 00000000
    Exception Code: c0000005
    Exception Data: 00000008
    OS Version: 6.1.7600.2.0.0.256.1
    Locale ID: 1041
    Additional Information 1: e98d
    Additional Information 2: e98dfca8bcf81bc1740adb135579ad53
    Additional Information 3: 6eab
    Additional Information 4: 6eabdd9e0dc94904be3b39a1c0583635
    2011-06-01T18:32:47+00:00
    Hello!
    I had a same problem it shows like:
    Application Name: explorer.exe
    Application version: 6.1.7600.16450
    Application Timestamp: 4aeba271
    Fault Module Name: SHSMP.DLL_unloaded
    Fault Module Timestamp: 3b968155
    Exception Offset: 0a90b520
    OS Version: 6.1.7600.2.0.0.256.48
    Locale ID: 2058
    Additional Information 1: 0a9e
    Additional Information 2: 0a9e372d3b4ad19135b953a78882e789
    Additional Information 3: 0a9e
    Additional Information 4: 0a9e372d3b4ad19135b953a78882e789
    Read our privacy...
    I have windows 7 installed on my computer, and when i try to do whatever i want to do, in any program, the computer crashes on, and it runs a dialog box with the message: "Windows Explorer has stopped working", what can I do with this problem for getting solved?
    Thanks for the help!
    2011-06-01T18:37:11+00:00
    Did you traying reinstalling Skype, Kizzy?
    2011-06-01T18:42:09+00:00
    There's not a free trial of this program or something?...
