Problem Event Name: BEX, error message
2009-05-19T18:52:36+00:00
I'm working on a tool which is used mainly for replacing the data source location of Crystal XI report batch, this tool is working normally, but when trying to replace data source location of some reports and mainly when looping on report tables to replace the data source of each table, a Bex error is raised
by the way, DEP feature is disabled using command ==>  bcdedit.exe /set {current} nx AlwaysOff
so
i need to know what is BEX error ?
why this error is raised when working with some reports not all of them?
how can i disable or work around this problem?
Thanks a lot.
Windows for home | Other | Apps
2009-07-03T16:32:16+00:00
Hi m.2,
Thanks for giving that information. It was indeed helpful.
BEX refers to Buffer Overflow Exception. For more details on BEX, kindly visit http://technet.microsoft.com/en-us/library/cc738483(WS.10).aspx
Could you please provide some more information? I have included a snapshot of a BEX error for your reference. Please post the snap shot so that I can get you the resolution.
Problem signature:
Application Name:          iexplore.exe
Application Version:       7.0.6001.18000
Application Timestamp:     47918f11
Fault Module Name:         ntdll.dll
Fault Module Version:      6.0.6001.18000
Fault Module Timestamp:    4791a7a6
Exception Offset:          00087ba6
Exception Code:            c000000d
Exception Data:            00000000
  OS Version:                6.0.6001.2.1.0.768.3
Locale ID:                 1037
Additional Information 1:  fd00
Additional Information 2:  ea6f5fe8924aaa756324d57f87834160
Additional Information 3:  fd00
Additional Information 4:  ea6f5fe8924aaa756324d57f87834160
Take care.
Regards,
Avash M
81 additional answers
    2015-12-12T15:56:43+00:00
    Problem signature:
      Application Name: shieldsoft.exe
      Application Version: 0.7.6.11
      Application Timestamp: 563739f8
      Fault Module Name: StackHash_0a9e
      Fault Module Version: 0.0.0.0
      Fault Module Timestamp: 00000000
      Exception Offset: 0019f0f0
      Exception Code: c0000005
      Exception Data: 00000008
      OS Version: 6.1.7601.2.1.0.256.48
      Locale ID: 1033
      Additional Information 1: 0a9e
      Additional Information 2: 0a9e372d3b4ad19135b953a78882e789
      Additional Information 3: 0a9e
      Additional Information 4: 0a9e372d3b4ad19135b953a78882e789
    2015-12-31T03:27:22+00:00
    I have the BEX error but for a 3d printer. The error only happens when I am scanning an object. The program is XYZscan.
    Problem signature:
      Application Name: 3D_Triangulation.exe
      Application Version: 0.0.0.0
      Application Timestamp: 56568088
      Fault Module Name: MSVCR100.dll
      Fault Module Version: 10.0.30319.1
      Fault Module Timestamp: 4ba1dbbe
      Exception Offset: 0008ae6e
      Exception Code: c0000417
      OS Version: 6.1.7601.2.1.0.768.3
      Locale ID: 1033
      Additional Information 1: 150b
      Additional Information 2: 150bebd24bb1483bcbcd5656b6e124ae
      Additional Information 3: 384f
      Additional Information 4: 384f4e497b19c395b86ab0f877724fe2
    I tried the DEP way but it dose not work. It says "This program must run with Data execution prevention (DEP) enabled. you can not turn off DEP for this program."
    Please help.
    2016-07-14T21:52:55+00:00
    I've been having issues and would like to see if anyone could troubleshoot this:
      Application Name:          risafoot.exe
      Application Version:       4.0.0.0
      Application Timestamp:     4f7e44ad
      Fault Module Name:         risafoot.exe
      Fault Module Version:      4.0.0.0
      Fault Module Timestamp:    4f7e44ad
      Exception Offset:          00032661
      Exception Code:            c0000409
      OS Version:                6.0.7601.2.1.0.256.48
      Locale ID:                 1033
      Additional Information 1: ef51
      Additional Information 2:  ef5178c05087aa00be8d4f443d423cd8b
      Additional Information 3:  4a94
      Additional Information 4:  4a945560335d0624d591e4f77ba96833
    2016-07-18T15:05:07+00:00
      Application Name: gta-sa.exe
      Application Timestamp: 547cd3a3
      Fault Module Name: gta-sa.exe
      Fault Module Timestamp: 547cd3a3
      Exception Offset: 0045f887
      OS Version: 6.1.7601.2.1.0.256.1
      Locale ID: 1050
      Additional Information 1: 8ffd
      Additional Information 2: 8ffdea3704244e772474bc42a44b5f40
      Additional Information 3: 4206
      Additional Information 4: 42063c349862c7916cebed7cdfeb1551
    That's my problem...i bought GTA san andreas from steam and i tryed to launch it and this happens,also i try all suggest on internet,and no help...
