Problem Event Name: BEX, error message
2009-05-19T18:52:36+00:00
I'm working on a tool which is used mainly for replacing the data source location of Crystal XI report batch, this tool is working normally, but when trying to replace data source location of some reports and mainly when looping on report tables to replace the data source of each table, a Bex error is raised
by the way, DEP feature is disabled using command ==>  bcdedit.exe /set {current} nx AlwaysOff
so
i need to know what is BEX error ?
why this error is raised when working with some reports not all of them?
how can i disable or work around this problem?
Thanks a lot.
Windows for home | Other | Apps
2009-07-03T16:32:16+00:00
Hi m.2,
Thanks for giving that information. It was indeed helpful.
BEX refers to Buffer Overflow Exception. For more details on BEX, kindly visit http://technet.microsoft.com/en-us/library/cc738483(WS.10).aspx
Could you please provide some more information? I have included a snapshot of a BEX error for your reference. Please post the snap shot so that I can get you the resolution.
Problem signature:
Application Name:          iexplore.exe
Application Version:       7.0.6001.18000
Application Timestamp:     47918f11
Fault Module Name:         ntdll.dll
Fault Module Version:      6.0.6001.18000
Fault Module Timestamp:    4791a7a6
Exception Offset:          00087ba6
Exception Code:            c000000d
Exception Data:            00000000
  OS Version:                6.0.6001.2.1.0.768.3
Locale ID:                 1037
Additional Information 1:  fd00
Additional Information 2:  ea6f5fe8924aaa756324d57f87834160
Additional Information 3:  fd00
Additional Information 4:  ea6f5fe8924aaa756324d57f87834160
Take care.
Regards,
Avash M
81 additional answers
    2014-05-31T13:46:46+00:00
    When I type this it says access denied. I am running Windows 8 on parallels by the way.
    2014-06-06T12:23:51+00:00
    I had the following happen when I tried to install Java and every time I ran a program that required it, it shut shut down
    Problem signature:
      Application Name: pcaui.exe
      Application Version: 6.1.7600.16385
      Application Timestamp: 4a5bc135
      Fault Module Version: 6.1.7600.16559
      Fault Module Timestamp: 4ba9b21e
      Exception Offset: 0001d79d
      Exception Code: c0000409
      OS Version: 6.1.7600.2.0.0.256.1
      Locale ID: 1033
      Additional Information 1: 3c5c
      Additional Information 2: 3c5cb3709f2b6088c8789a379feca2f1
      Additional Information 3: 30e4
      Additional Information 4: 30e462238840c4bfd266bb55dbd19e4d
    After doing a lot of looking around and not finding any answers that were working I decided to use an old trick I use to use a lot and go to www.bleepingcomputer.com and download a program called Combofix and ran it in safe mode. it gave a few BEX errors with it but once it finished and restarted in normal mode the java program installed and ran fine. still don't know what the problem was fully but as long as it works right. that iswhat matters
  3. Deleted
    2014-08-18T19:55:33+00:00
    hey . i have the same problem with hitman absoulotion. this is the bex error that i will get every time that i try to start a new game . any solutions?        Problem Event Name: BEX
      Application Name: HMA.exe
      Application Version: 1.0.438.0
      Application Timestamp: 50b5399f
      Fault Module Name: StackHash_0a9e
      Fault Module Version: 0.0.0.0
      Fault Module Timestamp: 00000000
      Exception Offset: 0012e3e4
      Exception Code: c0000005
      Exception Data: 00000008
      OS Version: 6.1.7601.2.1.0.256.1
      Locale ID: 1065
      Additional Information 1: 0a9e
      Additional Information 2: 0a9e372d3b4ad19135b953a78882e789
      Additional Information 3: 0a9e
      Additional Information 4: 0a9e372d3b4ad19135b953a78882e789
