Problem Event Name: BEX, error message
2009-05-19T18:52:36+00:00
I'm working on a tool which is used mainly for replacing the data source location of Crystal XI report batch, this tool is working normally, but when trying to replace data source location of some reports and mainly when looping on report tables to replace the data source of each table, a Bex error is raised
by the way, DEP feature is disabled using command ==>  bcdedit.exe /set {current} nx AlwaysOff
so
i need to know what is BEX error ?
why this error is raised when working with some reports not all of them?
how can i disable or work around this problem?
Thanks a lot.
Windows for home | Other | Apps
2009-07-03T16:32:16+00:00
Hi m.2,
Thanks for giving that information. It was indeed helpful.
BEX refers to Buffer Overflow Exception. For more details on BEX, kindly visit http://technet.microsoft.com/en-us/library/cc738483(WS.10).aspx
Could you please provide some more information? I have included a snapshot of a BEX error for your reference. Please post the snap shot so that I can get you the resolution.
Problem signature:
Application Name:          iexplore.exe
Application Version:       7.0.6001.18000
Application Timestamp:     47918f11
Fault Module Name:         ntdll.dll
Fault Module Version:      6.0.6001.18000
Fault Module Timestamp:    4791a7a6
Exception Offset:          00087ba6
Exception Code:            c000000d
Exception Data:            00000000
  OS Version:                6.0.6001.2.1.0.768.3
Locale ID:                 1037
Additional Information 1:  fd00
Additional Information 2:  ea6f5fe8924aaa756324d57f87834160
Additional Information 3:  fd00
Additional Information 4:  ea6f5fe8924aaa756324d57f87834160
Take care.
Regards,
Avash M
81 additional answers
    2013-09-11T07:23:35+00:00
    That's solved my issue. Thanks
    2013-09-23T08:01:31+00:00
    Goto Command Prompt as an administrator.
    type The following code and hit Enter.
    If the Task Shows successful result then you have your solution.
    2013-11-16T13:52:46+00:00
    Thank you ! It works !
    2013-11-22T22:28:45+00:00
    What if my BEX error is Outlook.exe?
