Problem Event Name: BEX, error message
2009-05-19T18:52:36+00:00
I'm working on a tool which is used mainly for replacing the data source location of Crystal XI report batch, this tool is working normally, but when trying to replace data source location of some reports and mainly when looping on report tables to replace the data source of each table, a Bex error is raised
by the way, DEP feature is disabled using command ==>  bcdedit.exe /set {current} nx AlwaysOff
so
i need to know what is BEX error ?
why this error is raised when working with some reports not all of them?
how can i disable or work around this problem?
Thanks a lot.
Windows for home | Other | Apps
2009-07-03T16:32:16+00:00
Hi m.2,
Thanks for giving that information. It was indeed helpful.
BEX refers to Buffer Overflow Exception. For more details on BEX, kindly visit http://technet.microsoft.com/en-us/library/cc738483(WS.10).aspx
Could you please provide some more information? I have included a snapshot of a BEX error for your reference. Please post the snap shot so that I can get you the resolution.
Problem signature:
Application Name:          iexplore.exe
Application Version:       7.0.6001.18000
Application Timestamp:     47918f11
Fault Module Name:         ntdll.dll
Fault Module Version:      6.0.6001.18000
Fault Module Timestamp:    4791a7a6
Exception Offset:          00087ba6
Exception Code:            c000000d
Exception Data:            00000000
  OS Version:                6.0.6001.2.1.0.768.3
Locale ID:                 1037
Additional Information 1:  fd00
Additional Information 2:  ea6f5fe8924aaa756324d57f87834160
Additional Information 3:  fd00
Additional Information 4:  ea6f5fe8924aaa756324d57f87834160
Take care.
Regards,
Avash M
81 additional answers
    2013-06-13T10:22:19+00:00
      Application Name: Darksiders2.exe
      Application Version: 0.0.0.0
      Application Timestamp: 50241afa
      Fault Module Name: MSVCR100.dll
      Fault Module Version: 10.0.40219.1
      Fault Module Timestamp: 4d5f0c22
      Exception Offset: 0008af3e
      Exception Code: c0000417
      OS Version: 6.1.7601.2.1.0.256.1
      Locale ID: 1033
      Additional Information 1: f0d5
      Additional Information 2: f0d5c9d35f3aeefcb66138e3d1a6839e
      Additional Information 3: 693e
      Additional Information 4: 693eaa60094807accfa3f8c540af91c3
    please tell me how to fix this???
    thnxxx
    2013-06-19T06:05:18+00:00
    if i did that and it still doesnt work what other way can i do
    2013-07-06T17:19:55+00:00
    i found a fix for the issue...
    . right click your app
    . go to compatibility tab
    . Enable Run as administrator
    . choose run your program compactible for win xp serveice pack 2
    . click ok
    This fixed my app crash and BEX issue..
    Enjoy :)
    You just made my day.  Worked like breeze.  Thanx
    2013-08-20T16:53:40+00:00
    Thank you very much.
