XBOX 360 wireless receiver won't connect to controller with Windows 7 64bit
2010-02-23T03:37:19+00:00
Hello, im having a problem with a xbox 360 wireless receiver on my windows 7 64bit, i installed the software that came with the receiver and it installed fine but when i went to connect the controller with the receiver it doesnt work, i've tried it dozens of times and i have rang microsoft for help but they werent too sure. Its a official controller which came with an xbox360 and the receiver isnt microsoft but i was told from the microsoft people that some receivers are made outside of microsoft but are still fine. I'm wondering if there is a specific windows 7 receiver driver for it?
thanks
james
Windows for home | Previous Windows versions | Gaming
2010-03-02T12:27:51+00:00
hey thanks i got it to work! so relieved. heres how you do it:
Right click on Computer
Go to Properties
Click on Device Manager
Right click on the Unidentified Device
Go to Properties
Go to the Drive tab
Click on Update Driver…
Browse my computer for driver software
Let me pick from a list of device drivers on my computer
Microsoft Common Controller for Window Class
Xbox 360 Wireless Receiver for Windows Version: 2.1.0.1349 [8/13/2009]
Update Driver Warning
Click Yes
i cant believe it was that simple, you dont need to download any seperate driver or anything, just follow the steps.
thanks
151 additional answers
    2011-06-14T07:03:24+00:00
    Life SAVERS!!!! although Im kinda ticked my brother just went to bed after playing games for 3 hours without me while I'd tried to figure it out... but anyways I can sleep peacefully now. thank you.
    2011-06-23T06:56:12+00:00
    This was very helpful was trying everything couldn't believe it was that simple
    2011-06-30T10:12:29+00:00
    OMG I actually love you for writing this it works now. Thought I had to get a new controller for (WINDOWS!) that would of been a pain.
    Thanks agan!!!!!!!!!!!!
    2011-07-07T03:49:28+00:00
    Such a shame you can't edit your original post because when I tried your instructions I couldn't find Windows Common Controller for Window Class, so I was about to give up, it was only later I saw your later post where you correct your mistake and say it should say Microsoft Common Controller for Window Class
    EG the correct fix (which worked for me) is:
    Go to Properties
    Go to Properties
    Go to the Drive tab
    Click Yes
    Thanks so much for the fix, you are a life saver.
