XBOX 360 wireless receiver won't connect to controller with Windows 7 64bit
2010-02-23T03:37:19+00:00
Hello, im having a problem with a xbox 360 wireless receiver on my windows 7 64bit, i installed the software that came with the receiver and it installed fine but when i went to connect the controller with the receiver it doesnt work, i've tried it dozens of times and i have rang microsoft for help but they werent too sure. Its a official controller which came with an xbox360 and the receiver isnt microsoft but i was told from the microsoft people that some receivers are made outside of microsoft but are still fine. I'm wondering if there is a specific windows 7 receiver driver for it?
thanks
james
Windows for home | Previous Windows versions | Gaming
2010-03-02T12:27:51+00:00
hey thanks i got it to work! so relieved. heres how you do it:
Right click on Computer
Go to Properties
Click on Device Manager
Right click on the Unidentified Device
Go to Properties
Go to the Drive tab
Click on Update Driver…
Browse my computer for driver software
Let me pick from a list of device drivers on my computer
Microsoft Common Controller for Window Class
Xbox 360 Wireless Receiver for Windows Version: 2.1.0.1349 [8/13/2009]
Update Driver Warning
Click Yes
i cant believe it was that simple, you dont need to download any seperate driver or anything, just follow the steps.
thanks
151 additional answers
    2011-10-25T10:58:28+00:00
    Please? Anyone reading this?
    The name of this has to be changed to "Play OR Charge" if we can figure out what the problem is...
    2011-11-02T19:37:49+00:00
    You legend! Thanks for taking the time to post this - I was starting to pull my hair out for buying a 3rd party receiver with dodgy drivers... but this fixed it ; )
    2011-11-02T20:08:53+00:00
    Go to Properties
    Go to Properties
    Go to the Drive tab
    Click Yes
    thanks
    I was getting ready to throw everything out of the window and sit in the corner of the room pulling my hair out! It took me ages to find help, thank you very much :) genius
    2011-11-20T00:09:13+00:00
    THIS!
    The required step of
    4. On the controller, press and release the Connect button. The Connect button is the small button on the front edge of the controller, between the
         left bumper button and the charging port.
    Was missing, and was crucial to making the thing work.
    After that, connected no problem.
    Note: Hold connect button on controller --> Then press button on receiver.
