XBOX 360 wireless receiver won't connect to controller with Windows 7 64bit
2010-02-23T03:37:19+00:00
Hello, im having a problem with a xbox 360 wireless receiver on my windows 7 64bit, i installed the software that came with the receiver and it installed fine but when i went to connect the controller with the receiver it doesnt work, i've tried it dozens of times and i have rang microsoft for help but they werent too sure. Its a official controller which came with an xbox360 and the receiver isnt microsoft but i was told from the microsoft people that some receivers are made outside of microsoft but are still fine. I'm wondering if there is a specific windows 7 receiver driver for it?
thanks
james
Windows for home | Previous Windows versions | Gaming
2010-03-02T12:27:51+00:00
hey thanks i got it to work! so relieved. heres how you do it:
Right click on Computer
Go to Properties
Click on Device Manager
Right click on the Unidentified Device
Go to Properties
Go to the Drive tab
Click on Update Driver…
Browse my computer for driver software
Let me pick from a list of device drivers on my computer
Microsoft Common Controller for Window Class
Xbox 360 Wireless Receiver for Windows Version: 2.1.0.1349 [8/13/2009]
Update Driver Warning
Click Yes
i cant believe it was that simple, you dont need to download any seperate driver or anything, just follow the steps.
thanks
151 additional answers
  1. Deleted
    2011-09-14T15:16:04+00:00
    Go to Properties
    Go to Properties
    Go to the Drive tab
    Click Yes
    thanks
    Awesome. Thanks buddy, just got mine working byu following your steps, really, thank you so much.
    2011-09-29T11:40:14+00:00
    I have had this problem, thought id solved it but now have a new problem.
    I followed these instructions and got the wireless gaming pad to work, but now t keeps losing the signal after a few minutes and wont reconnect, i read that other wireless signals can interfere with it so i changed the wireless channel that my router uses to a different one, but with no luck. I cant play any games because the gaming pad keeps disconnecting from the reciever, any suggestions?
    This is a really **** piece of hardware!
    2011-10-03T12:49:16+00:00
    Hi I
    Had the same problem, Thanx followed ur steps and its working awsom
    Enjoy the gaming
