Stop 9F Driver Power State Failure
2010-03-03T22:10:47+00:00
I frequently get STOP 9F bugchecks after my system has been running for awhile and I attempt to put it to sleep or hibernate.
Below is the Bugcheck Analysis:
Can anyone help with this?
0: kd> !analyze -v
*                        Bugcheck Analysis                                    *
DRIVER_POWER_STATE_FAILURE (9f)
A driver is causing an inconsistent power state.
Arguments:
Arg1: 0000000000000003, A device object has been blocking an Irp for too long a time
Arg2: fffffa80048ec060, Physical Device Object of the stack
Arg3: fffff800045fd518, Functional Device Object of the stack
Arg4: fffffa80043815f0, The blocked IRP
Debugging Details:
DRVPOWERSTATE_SUBCODE:  3
IMAGE_NAME:  pci.sys
DEBUG_FLR_IMAGE_TIMESTAMP:  4a5bc117
MODULE_NAME: pci
FAULTING_MODULE: fffff88000f78000 pci
CUSTOMER_CRASH_COUNT:  1
DEFAULT_BUCKET_ID:  VISTA_DRIVER_FAULT
BUGCHECK_STR:  0x9F
PROCESS_NAME:  System
CURRENT_IRQL:  2
STACK_TEXT:
fffff800045fd4c8 fffff800030f6e23 : 000000000000009f 0000000000000003 fffffa80048ec060 fffff800045fd518 : nt!KeBugCheckEx
fffff800045fd4d0 fffff80003093fa6 : fffff800045fd618 fffff800045fd618 0000000000000007 0000000000000000 : nt! ?? ::FNODOBFM::`string'+0x29330
fffff800045fd570 fffff80003093326 : fffffa800959f168 fffffa800959f168 0000000000000000 0000000000000000 : nt!KiProcessTimerDpcTable+0x66
fffff800045fd5e0 fffff80003093e7e : 000000b9fff258c5 fffff800045fdc58 00000000004e2373 fffff800032040e8 : nt!KiProcessExpiredTimerList+0xc6
fffff800045fdc30 fffff80003093697 : 00000030510838ce 00000030004e2373 00000030510838d4 0000000000000073 : nt!KiTimerExpiration+0x1be
fffff800045fdcd0 fffff800030906fa : fffff80003200e80 fffff8000320ec40 0000000000000001 fffff88000000000 : nt!KiRetireDpcList+0x277
fffff800045fdd80 0000000000000000 : fffff800045fe000 fffff800045f8000 fffff800045fdd40 0000000000000000 : nt!KiIdleLoop+0x5a
STACK_COMMAND:  kb
FOLLOWUP_NAME:  MachineOwner
FAILURE_BUCKET_ID:  X64_0x9F_3_NETw5s64_IMAGE_pci.sys
Followup: MachineOwner
<Original title - STOP 9F Driver Power State Failure>
2010-03-27T12:54:41+00:00
I hve identified the problem, but unfortunately do not have a solution. The problem is indeed the dirver NETw5s64.sys.
see --> http://communities.intel.com/thread/10055 for additonal discussion of the problem Intel needs to update this driver.
If I connect using a wired connection, all works as it should. I can put the system to sleep and wake it up as it should work. However, if I connect using the wireless connection, after using it for some amount of time, the computer will not sleep. THe screen goes blank, disk activity continues for some time and eventually the system gets to STOP 9F.
This and other prblems with this driver and discussed in the above link!!
47 additional answers
    2010-03-09T22:37:53+00:00
    Yes, I do have that update installed at least when I check the version the way it indicates at the bottom of the page for the above link it is 6.2.1.800 which is the version on that link.
    2010-03-09T22:38:52+00:00
    In any case, I'l install it again...
    2010-03-17T12:51:25+00:00
    What you marked as the answer, was NOT! The problem continues. As I look into this issue more and more, it seems that it has been around for some time on many different systems, generally with the same solutions (a driver problem) which not one seems to be able to find. My system, by the way is brand new and it has all the lastest everything on it, so there are no new drivers for me to add. I would suggest that Microsoft add additional code to Windows, so that someone could figure out what the problem is that creates the BSOD so it can be fixed!!!
    2010-03-17T16:56:57+00:00
    If the system is new and is experiencing bugchecks, I'd suggest contacting the manufacturer for warranty support.
