Stop 9F Driver Power State Failure
2010-03-03T22:10:47+00:00
I frequently get STOP 9F bugchecks after my system has been running for awhile and I attempt to put it to sleep or hibernate.
Below is the Bugcheck Analysis:
Can anyone help with this?
0: kd> !analyze -v
*                        Bugcheck Analysis                                    *
DRIVER_POWER_STATE_FAILURE (9f)
A driver is causing an inconsistent power state.
Arguments:
Arg1: 0000000000000003, A device object has been blocking an Irp for too long a time
Arg2: fffffa80048ec060, Physical Device Object of the stack
Arg3: fffff800045fd518, Functional Device Object of the stack
Arg4: fffffa80043815f0, The blocked IRP
Debugging Details:
DRVPOWERSTATE_SUBCODE:  3
IMAGE_NAME:  pci.sys
DEBUG_FLR_IMAGE_TIMESTAMP:  4a5bc117
MODULE_NAME: pci
FAULTING_MODULE: fffff88000f78000 pci
CUSTOMER_CRASH_COUNT:  1
DEFAULT_BUCKET_ID:  VISTA_DRIVER_FAULT
BUGCHECK_STR:  0x9F
PROCESS_NAME:  System
CURRENT_IRQL:  2
STACK_TEXT:
fffff800045fd4c8 fffff800030f6e23 : 000000000000009f 0000000000000003 fffffa80048ec060 fffff800045fd518 : nt!KeBugCheckEx
fffff800045fd4d0 fffff80003093fa6 : fffff800045fd618 fffff800045fd618 0000000000000007 0000000000000000 : nt! ?? ::FNODOBFM::`string'+0x29330
fffff800045fd570 fffff80003093326 : fffffa800959f168 fffffa800959f168 0000000000000000 0000000000000000 : nt!KiProcessTimerDpcTable+0x66
fffff800045fd5e0 fffff80003093e7e : 000000b9fff258c5 fffff800045fdc58 00000000004e2373 fffff800032040e8 : nt!KiProcessExpiredTimerList+0xc6
fffff800045fdc30 fffff80003093697 : 00000030510838ce 00000030004e2373 00000030510838d4 0000000000000073 : nt!KiTimerExpiration+0x1be
fffff800045fdcd0 fffff800030906fa : fffff80003200e80 fffff8000320ec40 0000000000000001 fffff88000000000 : nt!KiRetireDpcList+0x277
fffff800045fdd80 0000000000000000 : fffff800045fe000 fffff800045f8000 fffff800045fdd40 0000000000000000 : nt!KiIdleLoop+0x5a
STACK_COMMAND:  kb
FOLLOWUP_NAME:  MachineOwner
FAILURE_BUCKET_ID:  X64_0x9F_3_NETw5s64_IMAGE_pci.sys
Followup: MachineOwner
<Original title - STOP 9F Driver Power State Failure>
2010-03-27T12:54:41+00:00
I hve identified the problem, but unfortunately do not have a solution. The problem is indeed the dirver NETw5s64.sys.
see --> http://communities.intel.com/thread/10055 for additonal discussion of the problem Intel needs to update this driver.
If I connect using a wired connection, all works as it should. I can put the system to sleep and wake it up as it should work. However, if I connect using the wireless connection, after using it for some amount of time, the computer will not sleep. THe screen goes blank, disk activity continues for some time and eventually the system gets to STOP 9F.
This and other prblems with this driver and discussed in the above link!!
47 additional answers
    2010-03-03T23:03:31+00:00
    The bugcheck analysis points to the NETw5s64.sys, which is a driver for Intel wireless.
    You can try updating or rolling back that driver.
    However the problem could be elsewhere.
    Is ZoneAlarm or Norton Antivirus installed?
    2010-03-04T03:12:46+00:00
    I do not have ZoneAlarm or Norton Antivirus installed. I have a Lenovo T510 computer. I check the Lenovo web site and I have the latest driver installed for the Intel Ultimate N-6300. Lenovo. From checking their site, it appears this is an intial release, so I do not think I can roll it back or update it. Is there another choice?
    2010-03-04T13:54:30+00:00
    Can you locate the wireless adapter in the Device Manager under "Network adapters".
    What is the name of the adapter?
    Then can you right-click the wireless adapter > Properties > Details, then choose "Hardware Ids" from the drop-down menu under "Property".
    What is listed under "Value"?
    Can you then click on the "Driver" tab.
    What is the "Driver Date" and "Driver Version"?
    Is the "Roll Back Driver" button available?
    Also, have you any third party firewall installed and, if so, which one and which version?
    2010-03-04T15:18:26+00:00
    The name of the adapter is Intel(R) Centrino(R) Ultimate- N 6300 AGN
    Hardware IDs:
    PCI\VEN_8086&DEV_4238&SUBSYS_11118086&REV_35
    PCI\VEN_8086&DEV_4238&CC_028000
    Driver Date: 9/15/2009
    Driver Version: 13.0.0.107
    No "Roll Back Driver" button
    I have no third party firewall software and no anti-virus software installed. I have also disabled the windows firewall.
    Since you indicated that it was the wireless adapter, I have tried the following:
    The Lenovo T510 has a manual switch that turns off all radios (network and bluetooth). So far, if I turn the radios off and then put the comptuer to sleep, the computer sleeps normally. If I then switch the radios back on and wake the computer it seems to work OK. I have only done this a few times so perhaps it is not a work around yet...
