Sound Blaster X-Fi and Windows 7 64-bit
2009-10-23T03:31:55+00:00
I have a Sound Blaster X-Fi on a Dell XPS 710.  Installed Windows 7 64-bit.  Everything went great.  Downloaded and installed the new drivers from Creative for this sound card and Windows 7/64.  It installs but I get a staticy echo sound to everything.  Is there a fix?  The drivers are dated 6/2009.
2009-10-29T22:07:34+00:00
: WORKAROUND:
I claim NO responsibility if you mess this up but you can use this as a temporary work around until it is resolved by creative labs without removing memory... physically.
First run MSCONFIG
select the boot tab
select advanced options
under max memory select 3990 (or any value under 4 GB is fine IE anything less than 1024 * 4)
This will reduce the amount of memory that the PC uses which will allow you to hear the audio.  There is also BETA testing of newer drivers from Creative (the most recent batch of BETAS did not resolve the issue) that I am a part of.  When there is a working beta I will respond so we can all utilize our 64x machines.
75 additional answers
    2011-02-17T14:26:17+00:00
    Note:  I am running Windows 7 Ultimate 64-bit edition, using a Creative X-Fi.  Upgrading Windows 7 to SP1 does NOT resolve this issue--although the crackling is reduced, it is very much still there.
    Running with 3GB RAM is the only way I've found to run Creative drivers without crackling and audio distortion.
    The modded drivers referred to above do work, but the sound quality is drastically reduced compared to the Creative drivers.
    2011-02-23T21:04:20+00:00
    Woodenfluter, sorry to hear this solution did not work for you. As mentioned in my posts, I have only tested this on 32-bit systems. I was just thinking about upgrading to the 64-bit system.
    What version of Creative drivers are you using?
    You are correct about the modded drivers, it reduces sound quality dramatically. I forgot to mention that. Thanks.
    2011-03-03T10:57:47+00:00
    Finally i see that i'm not the only one who's having problem with my soundcard.
    I've got windows 64 with 6GB installed and when i'm playing a game the sound stops after a while. Even in the devicemanager the creative card is gone OMG.
    When i use the same pc but then with windows 32 bit (not more then 3.2GB in use but still 6 GB in the system) the games work fine and no stopping sounds. Even for hours no problem.
    I think that its a combination of 64bits and more than 4 GB of memory AND a x-fi soundblaster installed on your machine.
    The only solution i can think of is downgrading from 64bits to 32bits, but then again why have i bought a pc with more than 4 GB in it;) and use a 64bits OS?
    The question is: who must solve this problem course this is an Microsoft and/or Creative problem
    2011-03-04T23:53:23+00:00
    I assume you have Windows 7 installed. Have you tried installing SP1, or tried any of the other suggestions in this discussion? Can you be more specific about your sound card and the drivers you are using?
