Catalyst Control Centre: Host application has stopped working
2010-03-30T23:16:18+00:00
What does the error message "Catalyst Control Centre:  Host application has stopped working"  mean and how do I fix it??
2011-06-17T14:16:07+00:00
This may be the solution you are seeking.
I recently removed the Vista Recovery Center malware from another one of our company laptops. It has ATI graphics installed. This malware hides most of the files on the PC in an attempt to fool you into thinking that your PC is really damaged like it is reporting. Removing the malware does not undo the hidden aspects. In Vista, the c:\Users*"your profile name (usually Owner)"*  folder contains the AppData subdirectory that the Catalyst Control Center needs to access in order to function. When this directory is hidden, then CCC cannot locate the necessary files to launch. To fix this issue, I use the following steps.
Navigate to c:\ and right click on Users. Select properties. Under the General tab, look at the bottom for the Hidden selection. If there is not a check mark in the box, place a check mark there. Hit apply, select yes to apply to all subdirectories. If you clicked ok, you may notice that it disappeared from the right pane once it finishes. It should still be listed under the tree on the left. Right click on it again. This time remove the check mark and apply to all subdirectories. Once it has finished, your files in the Users directory should reappear and Catalyst Control Center should function normally again. This has worked in all cases that I have encounterd so far. Hopefully this works for you as well..
2010-04-05T17:44:45+00:00
Hi landbpeters,
You should be able to download the latest version of the Catalyst Control Center/drivers for your video card from here:
http://support.amd.com/us/Pages/AMDSupportHub.aspx
Hope this helps!
Debra
249 additional answers
    2012-04-28T07:38:38+00:00
    I had the same issue but did not lose the files and you probably didn't either.  If you right click on the parent folder i.e. "documents", "favorites" and go to properties in the general tab you can see how many files exist under those folders.  The problem is that they're hidden.  In that same tab if hidden is checked you will need to uncheck it.  In my case it was not checked but the files were still hidden.  I had to check hide, then apply to all subfolders.  Then I had to uncheck hide and apply to all subfolders.  All the files will reappear.
    Thank you Packfan 1. I got a virus last week which deleted all my files and pictures or so I thought. Followed your advise and low and behold now have all my files and pictures back. Thank you very much.
    Debbie
    2012-04-30T04:18:26+00:00
    This worked for me!  Thank you!  I have been having difficulty with this due to a windows update for sometime and new installs of CCC didn't work.  Once I did the first part and checked "hidden selection" it spent about a minute changing things and then my "user" folder completely disappeared.  I had to unhide that folder to then find the button for hidden selection again which then I had to recheck "hidden", apply, run... which then accomplished the task.  If you are a PC novice like me here is a link on how to unhide your folders if they disappear after the first step:  http://answers.yahoo.com/question/index?qid=20100510224402AAtI58t.
    I seem to be back to normal after about 6 months of frustration.  I use my HTPC to run a 59" big screen and I've been having an overscan issue I couldn't fix with my Radeon card until CCC was working again.
    Sweet!
    2012-05-01T21:31:54+00:00
    Hello all,
    Due to the age of this thread and to avoid any confusion we will now be locking this thread. If you are experiencing this issue, we ask you to please create a new thread here and provide all relevant information regarding your issue. Doing so will allow the community and us to focus more closely on your issue.
    Thanks!
