Catalyst Control Centre: Host application has stopped working
2010-03-30T23:16:18+00:00
What does the error message "Catalyst Control Centre:  Host application has stopped working"  mean and how do I fix it??
2011-06-17T14:16:07+00:00
This may be the solution you are seeking.
I recently removed the Vista Recovery Center malware from another one of our company laptops. It has ATI graphics installed. This malware hides most of the files on the PC in an attempt to fool you into thinking that your PC is really damaged like it is reporting. Removing the malware does not undo the hidden aspects. In Vista, the c:\Users*"your profile name (usually Owner)"*  folder contains the AppData subdirectory that the Catalyst Control Center needs to access in order to function. When this directory is hidden, then CCC cannot locate the necessary files to launch. To fix this issue, I use the following steps.
Navigate to c:\ and right click on Users. Select properties. Under the General tab, look at the bottom for the Hidden selection. If there is not a check mark in the box, place a check mark there. Hit apply, select yes to apply to all subdirectories. If you clicked ok, you may notice that it disappeared from the right pane once it finishes. It should still be listed under the tree on the left. Right click on it again. This time remove the check mark and apply to all subdirectories. Once it has finished, your files in the Users directory should reappear and Catalyst Control Center should function normally again. This has worked in all cases that I have encounterd so far. Hopefully this works for you as well..
2010-04-05T17:44:45+00:00
Hi landbpeters,
You should be able to download the latest version of the Catalyst Control Center/drivers for your video card from here:
http://support.amd.com/us/Pages/AMDSupportHub.aspx
Hope this helps!
Debra
249 additional answers
    2011-05-05T22:07:41+00:00
    Hmmm... This threrad will not allow me to post.
    2011-05-05T23:25:47+00:00
    Ahhhh....that's better!
    Fixed this issue.
    Go to:
    Program Files
       ATI
         CIM
            BIN
              ATI Setup
    Double click on the ATI Setup. and allow it to run.
    It will ask if you want to uninstall/remove/change...whatever..I already forgot!  Duh!
     Say YES
    This will uninstall the ATI SOFTWARE ONLY.....NOT the DRIVERS.
    My computer did not crash, my display did not revert to 1976, and I now have complete control of my laptop.
    So much for overly complicated Microsoft answers.  Win7 does not get along with CCC software but apparently no one will own up...either ATI or MS... so just remove it.
    Yes, it would be great to have the software function, but not at the expense of Zero Productivity and all this grief.
    And I repeat myself....Debbie, et al....learn how to say "I   DONT   KNOW".  This is akin to "If you don't have something good to say, then don't say anything".  If you don't ACTUALLY KNOW something, then say nothing.
    My nasty little post is considered GOOD for all of us poor fools who don't really know that we're doing and look to folks like you for HONEST answers.
    I know nothing about software & programming.  I am strictly a copy & paste, monkey see-monkee do...with ME being the head monkey!
    This worked for me.  I don't know what will happen to everyone else...because I DON'T KNOW.
    2011-05-09T21:55:53+00:00
    Hi landbpeters,
    Hope this helps!
    Debra
    The answer tells me nothing. I need to be told the steps to fix problem like you are talking to a 10 year old child. You have to explain problem and 1-2-3- etc.  steps to fix. Having the knowledge is worthless if you can not explain so a 10 year old understands.
    Try being more polite then! Not a please or thank you, just demands! I hope no-one helps you until you learn that people deserve your respect, especially those from whom there is something that you want.
