Catalyst Control Centre: Host application has stopped working
2010-03-30T23:16:18+00:00
What does the error message "Catalyst Control Centre:  Host application has stopped working"  mean and how do I fix it??
2011-06-17T14:16:07+00:00
This may be the solution you are seeking.
I recently removed the Vista Recovery Center malware from another one of our company laptops. It has ATI graphics installed. This malware hides most of the files on the PC in an attempt to fool you into thinking that your PC is really damaged like it is reporting. Removing the malware does not undo the hidden aspects. In Vista, the c:\Users*"your profile name (usually Owner)"*  folder contains the AppData subdirectory that the Catalyst Control Center needs to access in order to function. When this directory is hidden, then CCC cannot locate the necessary files to launch. To fix this issue, I use the following steps.
Navigate to c:\ and right click on Users. Select properties. Under the General tab, look at the bottom for the Hidden selection. If there is not a check mark in the box, place a check mark there. Hit apply, select yes to apply to all subdirectories. If you clicked ok, you may notice that it disappeared from the right pane once it finishes. It should still be listed under the tree on the left. Right click on it again. This time remove the check mark and apply to all subdirectories. Once it has finished, your files in the Users directory should reappear and Catalyst Control Center should function normally again. This has worked in all cases that I have encounterd so far. Hopefully this works for you as well..
2010-04-05T17:44:45+00:00
Hi landbpeters,
You should be able to download the latest version of the Catalyst Control Center/drivers for your video card from here:
http://support.amd.com/us/Pages/AMDSupportHub.aspx
Hope this helps!
Debra
249 additional answers
    2012-01-13T07:32:55+00:00
    Hi mike
    I have done what you said but when i right click on users in the left pane the hidden box is not checked and the folder is empty and now i dont have any desk top shortcuts etc. what should i do now?
    1. Click on the Start menu on bottom left of your screen
    2. On the right side above the "shut down" option move cursor onto empty space where all that stuff was and right click on your mouse.
    3. Click on Properties. (This will open Task bar and start menu properties)
    4.  Select the "Start Menu" tab.  Check the 2 boxes listed under privacy and hit apply
    1. On same page click on the tab that says "Customize".
    2. On the bottom of the tab click on "Use Default Settings". and click on ok.
    That should give you all of your shortcuts back in the start menu.
    If you are looking for your desktop icons (because they all disappeared like mine did)  the just follow these easy steps as well:
    1. right click anywhere on your desktop.  (This will open catalyst Control menu.)
    2. Select option that says "view"
    3. make a check mark in all 4 boxes.
    All of your shortcuts should be back on your desktop now except for your background picture.  You just need to select a background picture like you did before.
    Hope this helps!
    Greg
    2012-01-16T14:52:51+00:00
    Excellent, Mike. I followed the steps & they worked like a charm - Catalyst Control Center up & running again. Thanks for the advise!!!
    2012-01-18T03:55:18+00:00
    Tried this and lost the Users on the left pane - not good, any ideas. Using Windows 7
