Catalyst Control Centre: Host application has stopped working
2010-03-30T23:16:18+00:00
What does the error message "Catalyst Control Centre:  Host application has stopped working"  mean and how do I fix it??
2011-06-17T14:16:07+00:00
This may be the solution you are seeking.
I recently removed the Vista Recovery Center malware from another one of our company laptops. It has ATI graphics installed. This malware hides most of the files on the PC in an attempt to fool you into thinking that your PC is really damaged like it is reporting. Removing the malware does not undo the hidden aspects. In Vista, the c:\Users*"your profile name (usually Owner)"*  folder contains the AppData subdirectory that the Catalyst Control Center needs to access in order to function. When this directory is hidden, then CCC cannot locate the necessary files to launch. To fix this issue, I use the following steps.
Navigate to c:\ and right click on Users. Select properties. Under the General tab, look at the bottom for the Hidden selection. If there is not a check mark in the box, place a check mark there. Hit apply, select yes to apply to all subdirectories. If you clicked ok, you may notice that it disappeared from the right pane once it finishes. It should still be listed under the tree on the left. Right click on it again. This time remove the check mark and apply to all subdirectories. Once it has finished, your files in the Users directory should reappear and Catalyst Control Center should function normally again. This has worked in all cases that I have encounterd so far. Hopefully this works for you as well..
2010-04-05T17:44:45+00:00
Hi landbpeters,
You should be able to download the latest version of the Catalyst Control Center/drivers for your video card from here:
http://support.amd.com/us/Pages/AMDSupportHub.aspx
Hope this helps!
Debra
249 additional answers
    2011-12-20T16:51:45+00:00
    Tried this in Vista but lost all user directories, can't access hidden command in root directory to un-hide, can't see any user directory.  No command prompt available, can't find Restore Comm.
    All my fault!  Can you help?  Hal
    I managed to fix my disappeared directories in Win7 by using Help. Typed in "hidden" and got a selection of stuff.  Clicked on "Show hidden files" then "Click to Open Folder Options." Clicked on the View tab, then under "Hidden Files and Folders" I clicked on "Show hidden files, folders and drives."  It then asks if I want to apply this to all subdirectories, to which I replied "yes."  It took a few minutes to run, but when it finished I had all my desktop icons back and my users folder as well.
    Vista is no doubt similar to this.
    2011-12-20T20:22:22+00:00
    Found the pathway to un-hide the directories!  All better now.  Hal
    2011-12-21T20:23:18+00:00
    The users folder has totally disappeared and can't find it. Help!
