Catalyst Control Centre: Host application has stopped working
2010-03-30T23:16:18+00:00
What does the error message "Catalyst Control Centre:  Host application has stopped working"  mean and how do I fix it??
2011-06-17T14:16:07+00:00
This may be the solution you are seeking.
I recently removed the Vista Recovery Center malware from another one of our company laptops. It has ATI graphics installed. This malware hides most of the files on the PC in an attempt to fool you into thinking that your PC is really damaged like it is reporting. Removing the malware does not undo the hidden aspects. In Vista, the c:\Users*"your profile name (usually Owner)"*  folder contains the AppData subdirectory that the Catalyst Control Center needs to access in order to function. When this directory is hidden, then CCC cannot locate the necessary files to launch. To fix this issue, I use the following steps.
Navigate to c:\ and right click on Users. Select properties. Under the General tab, look at the bottom for the Hidden selection. If there is not a check mark in the box, place a check mark there. Hit apply, select yes to apply to all subdirectories. If you clicked ok, you may notice that it disappeared from the right pane once it finishes. It should still be listed under the tree on the left. Right click on it again. This time remove the check mark and apply to all subdirectories. Once it has finished, your files in the Users directory should reappear and Catalyst Control Center should function normally again. This has worked in all cases that I have encounterd so far. Hopefully this works for you as well..
2010-04-05T17:44:45+00:00
Hi landbpeters,
You should be able to download the latest version of the Catalyst Control Center/drivers for your video card from here:
http://support.amd.com/us/Pages/AMDSupportHub.aspx
Hope this helps!
Debra
249 additional answers
    2011-06-29T11:36:23+00:00
    I am having same problem. Just found this thread. I know very little about a pc. I have gone to documents and could not get to general tabs.  Could you walk me thru this procedure step by step in very simple terms?  I lost all my favorites and some of my desktop. And the alert keeps popping up. How can I stop that?  If you or anyone else can help me I would appreciate it.  Thank you from this old granny.
    2011-07-07T13:56:58+00:00
    Can you tell us what we do at this site?  Do we need to uninstall drivers before we install new ones and can this cause us some problems.  I do not even understand what the Catalyst center is for and don't want to mess up my computer?  Thanks so much for your help and could use some step by step details.
    2011-07-10T06:15:43+00:00
    Thanks, a lot. Worked like a spell, all back to normal & working as earlier.U r a time saver..it was quick. thanx agn for the help.
