Hi there,have you tried this?Right click an empty space on your desktop,highlight desktop icons,place a check on 'lock icons in place' and uncheck'auto arrange,?
How can I lock desktop icons?
I am unable to LOCK the icon items on my desktop. I have clicked right on the desktop and via properties checked lock items, yet they are easily moved and NOT locked. I've tried locking them thru 'Appearances and Themes', yet they will NOT lock. How can I get them to stop moving around and stay put by locking. Any help would be graciously appreciated. And, no I am not changing my resolution which I know moves them.
216 additional answers
2012-01-11T11:28:01+00:00 Hi George-Miami and others,
Thank you for visiting the Microsoft Windows Community site. In an effort to focus more attention on your particular situation create a new thread here. This will mitigate confusion caused by more than one posting about similar topics, allowing us to focus on each customer individually
2012-01-19T00:04:32+00:00 I have solved the problem by downloading a little free program called Icon Restorer. It allows you to copy the current desktop set up and then restore itif it is changed when you reboot.
2012-03-05T02:37:51+00:00 When you say "LOCK the icon items on my desktop" I'm assuming that you mean to keep them from re-arranging themselves with a reboot? If that is what you mean, then just copy then paste whats below to notepad, then click on "File>save as..." at the top, save it to the desktop. when you go to save it change the "Save as type" from "Text Documents (*.txt)" to "All Files" and name it anything with a .reg extension. then close everything and click on the file and choose "merge". also you want to make sure to add the part " Windows Registry Editor Version 5.00". that registry setting saves the position of items on the desktop when you shut down
[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer]
"NoSaveSettings"=hex(3):00,00,00,00
Wow Thanks for the great info and clear instructions. This has been driving me crazy for a while
2012-04-13T00:20:06+00:00 When you say "LOCK the icon items on my desktop" I'm assuming that you mean to keep them from re-arranging themselves with a reboot? If that is what you mean, then just copy then paste whats below to notepad, then click on "File>save as..." at the top, save it to the desktop. when you go to save it change the "Save as type" from "Text Documents (*.txt)" to "All Files" and name it anything with a .reg extension. then close everything and click on the file and choose "merge". also you want to make sure to add the part " Windows Registry Editor Version 5.00". that registry setting saves the position of items on the desktop when you shut down
Bullshit, Microsoft should do like xp, lock the desk top!
