yes, the drivers can be dowloaded from here: http://proaudiosoft.com/page4.html
Creative prodikeys driver for 64 bt
Hi, Creative have a keyboard which has a MIDI keyboard build in under the wristrest. Great idea but Creative can't be bothered to release driveers for Windows 7. The Vista drivers work for 32 bit Windows 7 but it seems impossible to get 64 bit Windows 7 to recognise the MIDI keyboard. I've installed the virtual XP on my machine but how can I get the drivers to install under the virtual XP (I assume it's in 32 bit mode) with out the 64 bit Windows 7 interfering with it ?
I'm asking here because Creative just refuse to discuss 64 bit issues :-(
Many thanks
Adrian
2011-02-16T14:37:33+00:00 -
2011-02-16T14:39:22+00:00 yes, they are 3rd party, and work with prodikeys perfect. I use my prodikeys with cubase, and sonar. drivers can be obtained from proaudiosoft.com , thx everyone
2011-02-16T17:32:34+00:00 Hi,
I've downloaded the drivers, but still no MIDI is detected on Sonar or other software.
What do you have to do once it has downloaded, do you have to download it into a certain folder?
Cheers
2011-02-16T19:28:49+00:00 - yes, they are 3rd party, and work with prodikeys perfect. I use my prodikeys with cubase, and sonar. drivers can be obtained from proaudiosoft.com , thx everyone
Hi mark, do you work for proaudiosoft? If so can you sort me out a refund for the drivers I bought? I tried contacting the support address and forum but no reply. Thanks
2011-02-16T19:34:52+00:00 - I tried contacting the support address and forum but no reply. Thanks
Exact same thing happened to me
