Creative prodikeys driver for 64 bt
2009-12-22T13:54:14+00:00
Hi, Creative have a keyboard which has a MIDI keyboard build in under the wristrest. Great idea but Creative can't be bothered to release driveers for Windows 7. The Vista drivers work for 32 bit Windows 7 but it seems impossible to get 64 bit Windows 7 to recognise the MIDI keyboard. I've installed the virtual XP on my machine but how can I get the drivers to install under the virtual XP (I assume it's in 32 bit mode) with out the 64 bit Windows 7 interfering with it ?
I'm asking here because Creative just refuse to discuss 64 bit issues :-(
Many thanks
Adrian
    2011-02-05T06:49:59+00:00
    There was a problem with certain motherboard bioses, but I can confirm the problem is fixed and the driver work with all systems.... http://proaudiosoft.com/page4.html
    2011-02-05T06:53:00+00:00
    Was like scratch moded. 32 bit drivers worked fine, but I had problems with the 64 bit drivers, on one system anyways. I just downloaded the latest drived on their site, and it works perfect now..... no more complaints :) http://proaudiosoft.com/page4.html
    2011-02-05T06:53:33+00:00
    can confirm is working on 64 bit too, thanks ....
    2011-02-05T06:55:16+00:00
    ha, i tried windows update, didnt work. reason being is the manufacturer isnt no longer supporting. I had wish, geez
    2011-02-14T18:24:55+00:00
    Hi Everyone,
    I have purchased and downloaded the driver from proaudiosoft.com, but it has not made any difference?
    I have probably done it completely wrong... Do I have to download it into a certain folder? What do I have to do once it has downloaded?
    Would be great to get this working :)
    Cheers Guys
