Creative prodikeys driver for 64 bt
2009-12-22T13:54:14+00:00
Hi, Creative have a keyboard which has a MIDI keyboard build in under the wristrest. Great idea but Creative can't be bothered to release driveers for Windows 7. The Vista drivers work for 32 bit Windows 7 but it seems impossible to get 64 bit Windows 7 to recognise the MIDI keyboard. I've installed the virtual XP on my machine but how can I get the drivers to install under the virtual XP (I assume it's in 32 bit mode) with out the 64 bit Windows 7 interfering with it ?
I'm asking here because Creative just refuse to discuss 64 bit issues :-(
Many thanks
Adrian
    2011-05-01T23:54:23+00:00
    it's all creative lab's fault for stopping support for the product.
    2011-05-02T14:02:36+00:00
    hi i am having the same problem, tried update. i installed xp version and programs are able to run but it does not detect the prodikeys.. anyone has the win7 driver
    2011-06-19T08:31:48+00:00
    Yeah, I do concur, I have prodikeys working on my windows 7 64bit system using the drivers from proaudiosoft.com , plainly stated, if your having an issue
    your not doing something right, start over from the top if you need to. If anyone needs help you can even email me, *** Email address is removed for privacy ***
    I have successfuly installed these drivers on about 8 of my clients machines. l8r days
    I'm moving from windowsXP to Windows7 pro 64bit, since you have the proaudiosoft.com drivers for Prodikeys PC-Midi working, and it's almost impossible to get that drivers anymore as the proaudiosoft.com is no longer exists (or if they still exists can someone messg me), can I buy from you the driver that works for windows7 64bit?... you can email me, mykamera_at_gmail_dot_com
    Thank you
    awaiting your reply
  4. Deleted
    2011-06-24T21:20:14+00:00
    that does not sound quite an answer. this simply does not work. updating driver in hardware manager does not install driver for Prodikeys. it will simply try to update the standard keyboard driver and will tell you that there is no updated driver for it.
    It seems like Creative Labs has abandoned and stopped supporting this product of their own. I will never buy a single product from Creative Labs again.
