How can I recover deleted files (with shift-del)
2009-04-16T02:21:41+00:00
How I can recover data files erased with shift-delete?
2009-04-16T11:10:01+00:00
When a file is deleted from your computer, its contents aren't immediately destroyed. Windows simply marks the hard drive space as being available for use by changing one character in the file table. If you manage to start an undelete process before Windows overwrites that part of hard disk with new files. You can set that flag back to "on" and get your file.
As I know, you can download some free recovery software as follow to recover deleted files.
Note:Stop using the current disk as main disk, please keep it unchangeable before recovering the files.
1.Panda Recovery
  Pandora Recovery actually recovers files permanently removed from Recycle Bin, files originally deleted using Shift
  • Delete keys bypassing Recycle Bin and files deleted from DOS prompt. Pandora Recovery allows you to find and recover recoverable deleted files from NTFS-formatted volumes, regardless of their type - you can recover pictures, songs, movies or documents. Setup file is 2.12 MB in size. For more information, please visit the following link.
Panda Recovery
2.TOKIWA DataRecovery
  DataRecovery is freeware and written by TOKIWA to undelete accidentally deleted files even from recycle bin. It supports FAT12, FAT16, FAT32 and NTFS undeletion. Even in both NTFS compressed files and EFS encrypted files. Zip file is only 198 KB in size, no installation required and it’s portable.
Download: TOKIWA DataRecovery
3.Undelete Plus
  Undelete Plus is a quick and effective way to restore accidentally deleted files. It can also recover files that have been emptied from the Recycle Bin, permanantly deleted files within Windows using the Shift + Delete, and files that have been deleted from within a Command Prompt. Undelete Plus works under Win 95/98/Me/NT/2000/XP/2003/Vista operating systems. The program supports all Windows file systems for hard and floppy drives including FAT12/16/32,NTFS/NTFS5 and image recovery from CompactFlash, SmartMedia, MultiMedia and Secure Digital cards. Program is only 583 KB in size and requires no installation. Portable. For more information, please visit the following web site.
 Undelete Plus
However, if you are not familiar with above application, I highly recommend that you contact Data Recovery Company for support.
Hope this helps.
179 additional answers
    2012-02-25T00:40:27+00:00
    On Fri, 24 Feb 2012 14:23:28 +0000, Lewis PeterKasongo wrote:
    i need my microsoft to be solve
    "Deleting" a file doesn't actually delete it; it just marks the space
    as available to be used. There are third-party programs that can
    sometimes recover deleted files. The problem is that the space used by
    the file is likely to become overwritten very quickly, and this makes
    the file unrecoverable.
    So your chances of successfully recovering this file are decent if you
    try recovering it immediately after deleting it, and rapidly go
    downhill from there. If you've been using the computer since then (for
    example to write this question and read this answer), your chances may
    be very poor by now.
    But if the file is important enough, it's worth a try anyway. Stop
    using the computer in question immediately, if you haven't done so
    already. Download an undelete program (here's one:
    http://www3.telus.net/mikebike/RESTORATION.html but there are several
    others to choose from; do a search) on a friend's computer and bring
    it to yours on a CD or thumb drive to try.
    If this fails, your only other recourse is to take or send the drive
    to a professional file recovery company. This kind of service is very
    expensive and may or may not work in your case.
    Ken Blake, Microsoft MVP
    2012-02-25T11:20:16+00:00
    Ok og tak for besvarelsen.
    Det er dukket et nyt fænomen op på min skærm.!!!
    Når jeg vil sende en E-mail, og jeg skal til at skrive E-mail adr.. dukker der en asteriks (*)  En hel stribe( ********************************** det viste er et eks. ) Hvad skal jeg gøre for at blive denne form for hjælp kvit.
    Får jeg dem ikke alle deleted, siger programmet, at det er forkert adr..
    MVH Hans K.
    2012-02-27T18:46:07+00:00
    Please select your language from the drop down list above to post your question in the language of your choice. The forum you posted in is for English only. If you do not find the desired language above, support options for additional international locations can be found by following the link below:
    http://support.microsoft.com/common/international.aspx
  4. Deleted
