How to run an executable internally along with other background processes in the system during the startup?
2010-07-30T03:39:55+00:00
I have an executable file and i want it to run continuously with other system processes in the background.
Can u tell me how to do that?
    2010-07-31T17:31:08+00:00
    Ya  came to know:)
    Actually i double clicked the killresp.exe file and saw in the task manager and the application was running and i once ended the process it got deleted and again came back and was visible.
    This shows its only stops when the system shut downs right?
    But i have to double click it every time the system is started.
    i want it to automatically get executed when the system is booted.
    And also after adding the path to the windows registry should i restart the system so that the system can execute the .exe file?
    Well, you stored the registry key data wrong then, provide a screenshot with that PATH open in Windows Registry.
    Itknowledge24.com
    2010-07-31T17:38:19+00:00
    The .exe file is alian and the screenshot is shown below.
    2010-07-31T17:41:28+00:00
    Yes, but add the "-auto" parameter infront.
    Like this: F:\Alian.exe -auto BTW, the F:\ driver might NOT be available untill Windows has loaded, therefore
    I suggest you put it in your dosuments folder C:\Users<your username>\Documents.
    Itknowledge24.com
    2010-07-31T17:43:26+00:00
    Oh ok wait:)
    2010-07-31T17:50:51+00:00
    Ok i added.
    Now also am not able to see this process in the task manager.
