How to run an executable internally along with other background processes in the system during the startup?
2010-07-30T03:39:55+00:00
I have an executable file and i want it to run continuously with other system processes in the background.
Can u tell me how to do that?
    2010-08-04T14:36:12+00:00
    It can be any project.
    Actually i have to submit the synopsis this saturday and we can start with the project and we have to complete it before december.
    And the implementation of the project should be done after that.
    I am not asking you to help me in doing the entire project and i know its very difficult.
    Just give me an idea what project i can do..
    Let it be c or c++ or Java etc.,.
    NOt sure, my best advice use C# and .NET and make something you want.
    Itknowledge24.com
    2010-08-04T14:38:18+00:00
    Thats what can you give the idea what can we do.
    Do you know anything about cloud computing and moss developing?
    2010-08-04T14:43:34+00:00
    C# applies well in Cloud computing, however, you must have
    a Server, and have to setup a set of API-keys, which C# can
    then invoke, like Twitter API for C#.
    From what I know, Simple Object Access Protocol or SOAP is used.
    Itknowledge24.com
    2010-08-04T14:46:35+00:00
    So what can we do exactly?
    What is SOAP actually?
    One of my teacher suggested to do something on cloud computing.
    2010-08-04T14:49:30+00:00
    Have the teacher teached you that?
    They must tell you to do something
    using what you now, and not ge beoynd
    your own skills (and way beoynd your own skills)
    and your teachers skills. SOAP isn't that easy,
    and SOAP is used in C#, however, you need
    API-key on the server, with public extern methods,
    and you need secret-key and token.
    So use PHP to make public external cloud API with API-key.
    Itknowledge24.com
